76 KZ900 A4 - Clutch Plate ?
- Summerheat
- Wanted at 17 Got it at 47 Worth The Wait!
07 Aug 2009 07:23 #312181
by Summerheat
1976 KZ900-A4
76 KZ900 A4 - Clutch Plate ? was created by Summerheat
Have read online about inch pounds of torque on clutch plate bolts.
I have replaced clutch, new springs & a Z1 roller push rod.
Ball bearing is in place and put all back together.
Bolts screw all the way in. Feel slight pressure of springs while installing, but torque all the way down?
Is this correct?
Is this correct?
1976 KZ900-A4
- Sandy
- Fly High,Tony
- Thank you received: 13
07 Aug 2009 07:51 #312187
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic 76 KZ900 A4 - Clutch Plate ?
Sounds about right.
Bolts torqued to about 95 INCH pounds?
1977 KZ1000 A-1
- mzandmz
07 Aug 2009 08:15 #312196
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic 76 KZ900 A4 - Clutch Plate ?
INCH pounds ,12 inch pounds = 1 foot pound. One pound pressed down at the end of a foot long rachet untill bolt stops turning. 90 INCH pounds = 7 1/2 foot pounds. Two ways to look at it. One pound pressed down on a 7 1/2 foot ratchet until bolt stops turning or , A one foot rachet pressing down 7 1/2 pounds until bolt stops turning. Thank you for attending AUTO SHOP 101 have a nice day.
- Summerheat
07 Aug 2009 08:24 #312198
by Summerheat
1976 KZ900-A4
Replied by Summerheat on topic 76 KZ900 A4 - Clutch Plate ?
Thank you both.
I guess I was thinking I was going to get X inch pounds of resistance from springs and didn't realize I was looking at a true torque down situation.
1976 KZ900-A4
