Cleaning valve cover assembly
- TheSnodge
06 Aug 2009 21:07
I'm changing my shims and while the valve cover is off I would like to clean it. What's the best thing to use on the cover, exhaust reeds, and the cap above the reeds? The grime is layered on. Carb cleaner?
1980 KZ1000 LTD. a.k.a. ThunderDome
- MFolks
Re: Cleaning valve cover assembly
06 Aug 2009 21:14
Be careful about what you use. Simple green might work, but avoid the Castrol spray cleaner as it will attack aluminum.
Check for compatabilty on the back of the spray bottles or liquid cleaners.
While you've got the cover off, why not remove the reed valves and install block off plates from www.aperaceparts.com
- TheSnodge
06 Aug 2009 21:37
Would the block off plates add to performance? I read a little about the top air assembly in the Clymer, but what exactly does it do?
- bowtie39
06 Aug 2009 21:39
And why would this be a good idea?? Not a attach but want to know the effects.
Thanks
Thanks
- MFolks
06 Aug 2009 22:03
I think if you go to these websites, they can explain about removing the reed valves and air switch assemblies on the Kawasaki Clean Air Suction System (CASS):
www.bore-tech.com
www.flowbenchtech.com
www.fastbygast.com
www.grccranks.com
www.dynoman.net
www.kzzone.com
www.bore-tech.com
www.fastbygast.com
www.grccranks.com
www.dynoman.net
www.kzzone.com
- Tyler
07 Aug 2009 08:17 - 07 Aug 2009 08:19
I have found that WD-40 and a brass brush will loosen gunk like that up. Then spay with carb cleaner or MEK. I cleaned the engine in my avatar (inside and out when I rebuilt it) with nothing more than WD-40, MEK and a brass pot scrubber. Took 40,000 miles of gunk off in minutes.
"74 Yamaha DT 400 Enduro
Last edit: 07 Aug 2009 08:19 by Tyler.
- Mcdroid
- Gone Kwackers
07 Aug 2009 08:49
Kawasaki recommends that the reeds are cleaned with a high flash-point solvent.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- donthekawguy
07 Aug 2009 12:27
Carb cleaner works good.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- TheSnodge
07 Aug 2009 21:59
donthekawguy wrote:
On the reeds too?
Someone suggested seafoam for the reeds, but I haven't seen it anywhere.
On the reeds too?
- PLUMMEN
08 Aug 2009 11:25
most auto parts stores sell sea foam
