Vance & Hines on a 1974 z1a
- iboone
- 1974 z1a 1977 kz1000 a1
04 Aug 2009 16:41 #311575
by iboone
Vance & Hines on a 1974 z1a was created by iboone
Does anyone know if i can take the packing outof the baffle on my new vance & hines and run it without causing any damage to my valves or engine? I have a stock breather with a k&n filter and I jetted up to 117.5 on the mains also I adjusted the air screws to onr turn out. I took the fiberglass out of the pipe and I like the sound and believe it has more power this way.
- keith1
- Thank you received: 2
04 Aug 2009 17:23 #311586
by keith1
Replied by keith1 on topic Vance & Hines on a 1974 z1a
if it runs good and you feel no ill effects....good to go...
if you hear a lot of popping on decell, some could be from a lean condition....you will get a little popping if running no baffle.....i would definitely keep an eye on the plugs for a while after doing what you are doing...they are a great indicator of whats going on inside...also make sure your valves are in spec as far as adjustment.....
- TerryK
- Thank you received: 3
05 Aug 2009 11:07 #311774
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Vance & Hines on a 1974 z1a
You shouldn't have a problem, except I can't see why you would want to make a great sounding pipe loud and raspy. Besides, you'll probably lose some horsepower and torque without the packing. I know it feels like it has more power, but it's probably just the loud pipe making it seem so.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- iboone
05 Aug 2009 17:00 #311837
by iboone
Replied by iboone on topic Vance & Hines on a 1974 z1a
I put the packing back because the plugs looked too lean but it still sounds pretty good.
- fastestz1
06 Aug 2009 05:57 #311955
by fastestz1
Replied by fastestz1 on topic Vance & Hines on a 1974 z1a
you know they have a street/strip baffle that sounds AWESOME for those pipes
- Thank you received: 2098
06 Aug 2009 09:39 #312003
by Patton
06 Aug 2009 09:41 #312004
by Patton
06 Aug 2009 09:43 #312005
by Patton
Replied by Patton on topic Vance & Hines on a 1974 z1a
- iboone
06 Aug 2009 14:25 #312050
by iboone
where did you get it and how much dothey cost?
06 Aug 2009 15:33 #312060
by Patton
- nads.com
06 Aug 2009 21:34 #312136
by nads.com
Replied by nads.com on topic Vance & Hines on a 1974 z1a
that pipe on the left is way too small and will hurt the high rpm power in a big way, ive used four pipes that size and it still chokes off the motor big time.
