stripped cam bearing caps
- avidflyguy
- roy-b-boy-b
- Thank you received: 103
- avidflyguy
- irishwill
- Thank you received: 6
any way to repair pulled out helicoils? my bike had helicoils in every one of the cam cap bolts, the inserts were the short ones that pulled out, now the only way to fix the the bolts that do not have the dowel to go through is with larger timeserts, what do i do about the locating dowels on the cam caps? you can't use the dowels if you install larger inserts. whoever repaired the head originally should have used longer helicoil inserts to begin with, otherwise i wouldn't be asking these ?'s any ideas for a suitable repair? or should i just scrap the head and look for another? anyone have an extra 81 and up j model head laying around to sell? what about heads off kz 1100s, will they work also?
I have a head that is "lying around"
I believe it to be an early gpz head...but am not positive...do you know the valve sizes?
or any other way to tell for sure?
- Mcdroid
- Gone Kwackers
- Thank you received: 317
one of my friends is a machinist and we came up with a repair that would be a permanent fix, i don't trust the helicoils or the timesert methods because there just isn't enough material being utilized to hold either method of repair, with the timeserts you can't use the dowels on the cam caps, we are doing all 16 cam cap bolts and will have the head back on next week sometime, after looking at all the repair methods out there, this will be a permanent fix and no worries about a helicoil failing on you miles from home. will keep you posted on this and see if it will work.
You have my interest...keep us informed.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
I've tried two different methods, both with success.
I've drilled and re-tapped for an M8 bolt. But you can't do that where the pins are.
I've also used these thread inserts . The drill bit size needed for these fits inside the existing hole for the knock pin. So after drilling and tapping for the insert, the knock pin still fits snug in its original hole.
West Linn, OR
- avidflyguy
- avidflyguy
