RTV on Side cover gaskets or No?
  • deezil
  • deezil's Avatar Topic Author
02 Aug 2009 13:52
#310929
I Received my left side cover gasket for my 1978 kz200 yesterday. Im wondering if I need to use rtv on either side of the gasket before I put it install the left side case cover?
This is a wet side on this bike.
So...Thin film on both sides of the gasket or put it on without it?
Thanks
  • bountyhunter
  • bountyhunter's Avatar
Re: RTV on Side cover gaskets or No?
02 Aug 2009 14:01
#310930
I used a film of the black ultra high temp gasket maker stuff on mine. Theoretically, you shouldn't need it, but I hate oil leaks.
  • thompsonmx100
  • thompsonmx100's Avatar
02 Aug 2009 14:42
#310939
You shouldn't need any thing if you have gasket. If you do use some use a small amount. dont want to clog any oil passages
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • Nebr_Rex
  • Nebr_Rex's Avatar
02 Aug 2009 14:45
#310941
never use rtv silicone where it can get to the internals of your engine.it can and will plug oil passages.use 1104/1194,yamabond,kawabond etc.,they are the same.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • deezil
02 Aug 2009 19:40
#310976
I Ended up using a thin coat of gasket tack on either side of the gasket.
I am going to ket it sit for a few days before I refill the oil. Should be good to go.
Thanks for all the help!!
Hopefully I can be riding this dang thing before the weeks ou!
  • mzandmz
  • mzandmz's Avatar
02 Aug 2009 22:37
#311002
I use my favorite Permatex Aviation Gasket sealant. Its a alcahol based black goo that stays pliable and keeps oil in and water out. Has a brush aplicater and easy clean up.Sorry about my spelling. I cant no how to spel:lol: :laugh:
New to Family, 1979 KZ440 LTD
  • Old Man Rock
  • Old Man Rock's Avatar
03 Aug 2009 04:06 - 03 Aug 2009 04:08
#311099
Permatex Copper gasket spray....
Crap is Magic and your gaskets don't seem to bake/stick to the engine case surfaces after being run for awhile....
Just spray both sides of your gasket a couple thin coats and after a couple of minutes flash time to become tacky, install....
I used this on my cylinder & head gaskets as well... Not one leak what so ever.... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 03 Aug 2009 04:08 by Old Man Rock.
  • N0NB
  • N0NB's Avatar
  • Blue handles better
03 Aug 2009 04:20
#311102
I've not tried the Copper spray. Looks interesting.
My recommendation is Parmatex Black gasket sealer. It remains pliable and doesn't require a BFH and BFC to open your cases again.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
