KZ650 in a KZ550 frame?
  • EtienneS
  • Topic Author
  • Custom 1981 KZ550d
02 Aug 2009 11:19 #310920 by EtienneS
KZ650 in a KZ550 frame? was created by EtienneS
:huh: As you guys can see from my avatar pic, I have a custom 1981 custom KZ550 fitted with a KZ550 D motor. I believe this motor is also a GPZ550 motor.
I don't get spares for a KZ550 or a GPZ550 here in South-Africa. That got me thinking ...
Can I fit a Z650 motor? Those are quit popular here in S.A.
I now you smart and very wise guys out there has given this a though some time.
04 Aug 2009 11:11 #311509 by rstnick
Replied by rstnick on topic KZ650 in a KZ550 frame?
Not sure it would be a dirrect swap, but if some can put a kz1000 engine in a kz650, I'd think the 650 engine should fit in a 550 with possable engine mount adjustments made.
Let us know if you make it work!
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
04 Aug 2009 12:25 #311515 by KawiConvert
Replied by KawiConvert on topic KZ650 in a KZ550 frame?
Measure your engine mounts and I'll give you what the 650 engine has. Thats the best bet without actually doing it.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • EtienneS
  • Topic Author
04 Aug 2009 12:45 #311519 by EtienneS
Replied by EtienneS on topic KZ650 in a KZ550 frame?
how do I go about measuring it? What do you need?
04 Aug 2009 16:50 #311576 by KawiConvert
PM sent.
04 Aug 2009 20:48 #311622 by PLUMMEN
Replied by PLUMMEN on topic KZ650 in a KZ550 frame?
are you sure youre up to this? :laugh:
05 Aug 2009 03:12 #311688 by loudhvx
Replied by loudhvx on topic KZ650 in a KZ550 frame?
If you can't do cutting and welding, it's not going to bolt in. The 650 motor is significantly different/bigger than the 550.
  • hugo
  • '92 Zephyr 750
05 Aug 2009 04:24 - 05 Aug 2009 04:25 #311690 by hugo
Replied by hugo on topic KZ650 in a KZ550 frame?
And as the 750 is same size as the 650, why not the 750 for the same trouble?
Last edit: 05 Aug 2009 04:25 by hugo.
05 Nov 2010 17:48 - 05 Nov 2010 17:50 #411041 by Injected
Replied by Injected on topic KZ650 in a KZ550 frame?
Did anybody ever find out how difficult this was?
I am asking because I have a chance to pick up a complete '85 GPZ550 without a motor/carbs/exhaust for cheap... everything else is there.
I can weld/cut/fabricate... and I have a spare 650 motor/carbs/exhaust sitting in the corner.
The motors look similar in pictures... engine mounting points look very close - the 650 motor must be wider for sure... maybe a bit taller?
Any ideas?
Last edit: 05 Nov 2010 17:50 by Injected.
06 Nov 2010 06:14 #411161 by kopcicle
Replied by kopcicle on topic KZ650 in a KZ550 frame?
..sure , why not ?
"There are two major pressure changes in a four stroke internal combustion engine , when you light the fire and when the rods exit the block..."
06 Nov 2010 06:23 #411162 by dejavoodo41
Replied by dejavoodo41 on topic KZ650 in a KZ550 frame?
Yeah Baby! Now that's a Pit Bike!:woohoo:
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
