Stage1,2,or 3
  • ohioKZnut
  • ohioKZnut's Avatar Topic Author
Stage1,2,or 3
02 Aug 2009 05:16
#310869
I'm just full of questions,just got a 78 kz650.
Can someone tell me how i can tell what stage upgrade my bike has?Is there a way to tell?For now it has k&n cones,hgk wires and plugs,and the 4 into 1 exhaust,that says Kawasaki on the header part(is that a factory 4 into 1?)
As far as carb and jets,i just don't know.
Thanks y'all for any input
78 KZ 650
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Stage1,2,or 3
02 Aug 2009 06:07
#310872
Well, for starters, there is no 'Stage 1, 2, or 3' for the older bikes. There are merely aftermarket upgrades/changes (some would argue with the term 'upgrade' :) ) to ostensibly make the bike run/look better. You have a series of changes to your bike that are non-stock.
1. The header is a Kerker sold to the Kawasaki market (you'll realize that Kawasaki and Kerker is a natural marriage) but it did not come from the factory that way.
2. K&N pods are some of the better ones you can get.
3. Spark plug wires are aftermarket.
Since your bike has both the pods and header, it is likely that jet sizes have been altered (particularly if the bike runs well now). However, what those changes are won't be revealed until you open up the carbs...and if the scooter is running well, don't mess with it.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • bill_wilcox100
  • bill_wilcox100's Avatar
Re: Stage1,2,or 3
02 Aug 2009 07:43
#310892
Welcome to WKZR your all KZ station... you are in the right place.
To echo Mcdroid, if it ain't broken, just ride it.
BTW, what's the story with the seat cover? Did the PO redo it or is it just streached? There are some nice replacement covers out there in the $65-$70 USD range if this ever becomes one of your do-list items... that's the direction I took.
Looking good! Best of success. :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
  • KawiConvert
  • KawiConvert's Avatar
Re: Stage1,2,or 3
02 Aug 2009 08:09
#310895
If your taking the stage 1, 2, or 3 from the shop manual, without cracking the head cover you are at least a stage 1 of performance increases. I think it is the Clymer manual that has this in the back.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • 2006hhr
  • 2006hhr's Avatar
Re: Stage1,2,or 3
02 Aug 2009 11:01 - 02 Aug 2009 11:03
#310917
If you want to identify by stages, i would say it is stage 2
Criteria being:
Stage 1 K&N drop in filter and 4:1 or 4:2 aftermarket exhaust
Stage 2 K&N Pods or similar and 4:1 free flowing exhaust with jetting to match
Stage 3 Same as stage 2 with interior engine mods (cams, pistons, etc)
Stage 4 NOS or Super/Turbo setup
This is by no means a scientific or set in stone criteria, just how i would see it. I have what i would call a stage 2 setup on my '78 KZ650 SR. K&N pods, carbs jetted to match, Vance and Hines 4:1 and Dyna coils with aftermarket wires. Next step for me would be a set of cams. Probably the Megacycle 471-00 or Web Cam 118 grind, nothing too serious. Would like to eventually go with the Wiseco 700 kit when the 650 gets tired, but right now i am having too much fun.
Last edit: 02 Aug 2009 11:03 by 2006hhr.
  • KawiConvert
Re: Stage1,2,or 3
02 Aug 2009 18:29
#310968
The clymer had is something along the lines of
1) Filter and Exhaust
2) 1+ Cams and porting
3) 1+2+ big bore
Essentially with how much was required to do each step.
