help please
- 1981 ltd
31 Jul 2009 18:29 #310610
by 1981 ltd
help please was created by 1981 ltd
i have a 1981 kz1000 ltd with 29mm smooth boores just recently i got a miss between 4,6 grand i changed the main jets from 118 to 115 and i got rid of the midrange miss but now i have a low end miss the pilots are 27.5 i had no problems until about a week ago it ran just fine if anyone can help with this problem it would be appreciated thank you
- mzandmz
31 Jul 2009 18:41 #310615
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic help please
Probly the "Corn"fuel thier adding.:silly: :dry:
- KawiConvert
- Thank you received: 4
31 Jul 2009 22:00 #310671
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic help please
What RPM range is the low end miss?
- 1981 ltd
31 Jul 2009 22:04 #310672
by 1981 ltd
Replied by 1981 ltd on topic help please
the bike idles fine but when you take off the miss starts as soon as you put a load on the motor to take off starts around 1200 clears up about 2500 but in nuetral you can rev the motor up without a problem
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
31 Jul 2009 22:06 #310674
by kzz1p
Replied by kzz1p on topic help please
27.5 is way to big for a pilot jet. Maybe 17.5, would work just fine. It should not need anything bigger.
- 1981 ltd
31 Jul 2009 22:13 #310676
by 1981 ltd
we went thru all the pilots from stock up to 27.5 its a j head so i dont know but it seemed to want alot moore fuel when i set it up it ran like a scalded dog all summer till last week and i changed nothing jusomething electricalt started running like crap its got me confused on if its carbs or s
- roy-b-boy-b
- Thank you received: 103
01 Aug 2009 04:45 #310697
by roy-b-boy-b
Replied by roy-b-boy-b on topic help please
Check your valve clearance. I have been chasing down a miss on 1and 4 cylinder and after going through the electrical i checked the vales and 1 and 4 had no clearance. Run like crap unless it was wide open.
17.5 should be fine on pilot jet. Roy
- TeK9iNe
- What did you do!?!
- Thank you received: 28
01 Aug 2009 07:29 - 01 Aug 2009 07:31 #310715
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic help please
1981 ltd wrote:
Thats exactly the problem I'm having!
I think I have a pooched coil. After changing to really good wires, and new plugs, with 12V @ the coils, it runs much smoother.
But still an occasional miss...
I have a colortune plug (you can see thru the plug into the combustion), and the spark starts to weaken (turn yellow), then dissappears completely till I rev it. Then it comes back blue, but starts to weaken/die again @ idle.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 01 Aug 2009 07:31 by TeK9iNe.
