Clutch Slippage or Electrical Problem?
- Bullitt03737
Fix one problem only to find another.. Now that the bike is making more power based off of my buttdynamoter when I rev her out wide open and it hits about 6K it sputters real bad and dosent want to go.. It was doing this before I synced the carbs but it wasnt anywhere near as bad..
Is this the clutch slipping? or A coil leaking and cutting spark energy? How do I go about figuring this one out?
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- KZQ
- Administrator
- Thank you received: 1415
Just dialed in my carbs and synced them up real good and it runs super smooth idles real good etc.
Doesn't sound like a slipping clutch, that wouldn't equate to anything like sputtering.
Assuming that your ignition is not at fault, I wonder about your mixture. What do your plugs look like?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- Bullitt03737
I know its time for a rebuild at least on the heads, it will burn some oil after sitting for a few days.
- brianrae33
1982 kz1000ltd
- Bullitt03737
