Hot-weather oil. Input?
- charwood89
When not running in super-hot weather, I'm usually riding in coastal Washington (50-60 degrees) so I'm leaning toward the synthetic.
I'm juggling the options of running a dino 20w50 for increased viscosity and of switching to a synthetic for better stability.
- Would the Rotella T synth 5W-40 be a heavy enough oil for hot running? I like rotella because it's good oil and its cheap.
- Should I go with a 15w-40 synth to match my current weight?
- Or should I stick with dino and go to 20w50?
Thanks,
Casey
- charwood89
- Old Man Rock
- Thank you received: 225
Coming soon an oil cooler, no other way about it...
Synthetic oil break down woould be better but from what I've researched, at these temps an oil cooler is the way to go....
20w/50 @ under 100*F, you should be fine...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If you're runnin dino, and plan on switching to synth, thats fine if you plan on using that oil from then on.
Switching oils, no matter how much flush or whatever you decide to shorten your clutchs' life span with you use, will always leave sludges from incompatibles in the oils.
Its not terrible, it just happens. Its ok so long as your not flip/flopping oils all the time.
If say you are using castrol 10w30, go to a 10w40, or 10w50 (synth probly) if you can find it.
I don't know if I'd use the 20w** stuff, it makes a really big difference in these motors, almost sluggish.
Here's some info to ponder for the future...
Good Luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- charwood89
- Thank you received: 2829
Synthetic Bike Oil
- bountyhunter
- Thank you received: 337
I sometimes do a 50-50% mix with 20W-50 dino and 10W-40 synthetic for summer.
Thanks,
Casey
- bountyhunter
Flushing is not necessary and not recommended unless the engine is really filthy. The best engine flush is clean oil, it's loaded with detergent. If the engine is dirty, just do more frequent change intervals with dino oil.Also, I'm aware the flushing the engine is not necessary, but is recommended. Could I just dump a half-bottle of seafoam in and run it for 30 miles or so before doing to oil change?
- bountyhunter
The data I have seen indicates Rotella (a diesel service rated oil) has a very strong additive package that resists viscosity breakdown from the shearing of the VI's (viscosity increasers). It is one of the best dino oils around for bikes and probably would suffice for your usage.I use Rotella T 15W-40 dino right now, or another high shear diesel oil of the same weight (Delo, Delvac.) I've used these oils for the past 7,000 miles, but I'd like some higher head-handling capacity. I'll look into an oil cooler, but I'm not planning on keeping the bike for much longer, so I'd just like to make sure that the oil can handle some heat for this big ride of the summer. I'll also boost my main jets from 130 to 135, even if it is a little on the rich side.
If you want to get the best oil for severe service, I think Amsoil synthetic is tops based on what I have seen. Because it is pure true syn, it requires almost no VI's added which means it holds a very stable viscosity over use.
Regarding the ZINC: I think bikes need it and I add it to mine. You can buy it as an additive with ZDDPlus.
www.zddplus.com/
- charwood89
Yeah, that's what I've heard about Rotella and the other detergent diesel oils. That's why they're my favorite dino oils. But would the Rotella synthetic 5w40 have the same favorable high-shear performance with added high-temp stability? ...Or would the drop from 15w40 to 5w40 negate that with a viscosity decrease?
I like the 50/50 mix you mentioned. Maybe 5w40 rotella synth with a good quality 20w50 dino.
Thanks. I know there's never going to be a consensus on the "best" oil to use, but I'm picking up some really helpful info.
