- Thank you received: 4
Starter whoas
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
27 Jul 2009 13:09 #309648
by wagonmaster69
Starter whoas was created by wagonmaster69
I have a 82 KZ1100 Spectre and my starter went out. At first when I got the bike I would hear a clanking like noise and it would start and then last week I went to work and tried to move it (to get better parking) And nothing the starter just spins. All I hear is the starter whine. I'm going to take the side cover off what should I look for? I love riding my Big Nasty. So come on KZR Pros I got the bat signal up and need all your help..
- bountyhunter
- Thank you received: 337
27 Jul 2009 13:56 #309661
by bountyhunter
Replied by bountyhunter on topic Starter whoas
If it spins, it sounds like the starter clutch is not engaging.
- wagonmaster69
27 Jul 2009 16:24 #309701
by wagonmaster69
Replied by wagonmaster69 on topic Starter whoas
when you take the cover off how can you tell if the starter clutch is bad.
- MFolks
- Thank you received: 540
27 Jul 2009 17:39 #309715
by MFolks
Replied by MFolks on topic Starter whoas
The over running starter clutch is behind the rotor for the alternator on the left side of the engine.
Before you start, have a new alternator side cover gasket on hand plus the new springs and rollers. They wear out over time and need replacing.
The cover will need removing, the rotor pulled and then the starting clutch can be accessed.
Put the bike on the center stand (if you have one) and lean it to the right to mimimize the small amount of oil to be lost. An oil change pan works good for this.
- Grantl
- KZRider is Da Bomb!!!
27 Jul 2009 19:52 #309764
by Grantl
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
Replied by Grantl on topic Starter whoas
In order to remove the rotor you might needa 14 mm bolt with a ball bearing behind it to drive the rotor off the end of the crank shaft. When you actually take off the starter clutch, the rollers and springs might fall out. Look for 3 rollers, 3 springs and 3 spring caps. Replace the rollers, springs and caps. There is a thrust washer (looks like a shim that goes in between the starter clutch and the idler gear. Dont forget to put that in when reassembling.
Oh, the best tip for reassembly is to put grease in the roller cavities to keep the rollers in place when you go to put the starter clutch back on the crank, otherwise they keep falling out. Before you try to torque the bolt that holds the rotor on the crank, put the bike in 1st gear, then have your son stand on the rear brake pedal. If you have problems call me. I will be in New Orleans and also Mississippi until Friday, but will be available after that.
Grant
Grant
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
- fweep
- 2001 ZRX1200R, 1991 KZ1000P, 1984 V45 Honda magna
28 Jul 2009 10:50 #309861
by fweep
Replied by fweep on topic Starter whoas
You should be able to test the starter clutch and then decide if you need to take of the Alternator rotor.
When you get the covers off and the alternator off, you can remove the starter idler gear that is between the starter and the starter clutch.
On my 1992 KZ1000P you test the starter clutch by seeing that it turns freely to the right ( clockwise) and does not turn to the left (counter clockwise) at all.
Mine spun freely to the right with hand pressure.
So my starter clutch was OK.
As always check your model specific engine manual to be sure...
- wagonmaster69
28 Jul 2009 15:13 #309907
by wagonmaster69
So if it dose not turn left its good right.
- Kawickrice
- Thank you received: 18
28 Jul 2009 15:42 #309912
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Starter whoas
A loose rotor will make a clunking noise also, and the gear will be loose to so the starter can not engage. The big bolt on the triple tree is the rotor puller on the 900/1000
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- wagonmaster69
22 Aug 2009 20:40 #315850
by wagonmaster69
Finally after waiting about four week got the tool to take off the rotor just to find out it was the three bolts that sheared off. o well i guess i need to get three bolts and loctite.
- MFolks
22 Aug 2009 21:33 #315856
by MFolks
Use the BLUE Loctite not the RED as the former is hand tool workable but the RED takes about 300 F to loosen up,far more than is safe for the magnetic rotor.
- wagonmaster69
22 Aug 2009 21:40 #315857
by wagonmaster69
Thanks for the heads up on the Loctite MFolks.
