Top End KZ1100
- KZ1100 Bully
26 Jul 2009 16:08 #309437
by KZ1100 Bully
1983 Kawasaki KZ1100 Spectre D2
Top End KZ1100 was created by KZ1100 Bully
Hi, I have to take the cylinder head off because I have a broken exhaust stud and head that needs to be welded back on. I also have a really lose cam chain. I bought a Ape cam chain tensioner and it took up the slack.
I already bought a new chain and link and all the guides for the chain. I was also going to replace the valve guide seals sense I was in there.
My question is what else should I replace while I have the cylinder and the head off?
Just wanted to do a light freshening of the top end.
Thanks
Thanks
- PLUMMEN
- Thank you received: 104
26 Jul 2009 16:16 #309440
by PLUMMEN
Replied by PLUMMEN on topic Top End KZ1100
anything that looks questionable,valve job and seals?
- KZ1100 Bully
27 Jul 2009 03:36 #309535
by KZ1100 Bully
Replied by KZ1100 Bully on topic Top End KZ1100
Not really sure what to look for. The bike runs strong does not burn any oil but has 40K miles on it. When you say a valve job do you mean the shims?
- PLUMMEN
27 Jul 2009 04:41 #309537
by PLUMMEN
check the valves to make sure theyre sealing,if not have valves ground check guides and seals and springs while youre in there
- kawsakiman
- Thank you received: 6
27 Jul 2009 05:31 #309546
by kawsakiman
Replied by kawsakiman on topic Top End KZ1100
At a minimum I would lap the valves and replace the springs and seals. then bench shim it.
- KZ1100 Bully
27 Jul 2009 09:09 #309577
by KZ1100 Bully
Should I use oem parts or after market parts? I would like to upgrade the parts if posssible. I Little better performance if I can.
so far:
Cam chain and guides
lap the valves
replace the springs and valve seals.
bench shim it
Anything else that while the top end is off?
Was thinking about the rings?
so far:
lap the valves
bench shim it
- kawsakiman
27 Jul 2009 09:36 #309595
by kawsakiman
if you have not yet, i would run a compression test before removing the head.
if it's good, why replace the rings?
this is how it starts.
just a little "clean up"
next thing you know your looking at www.kzzone.com
and www.z1enterprises.com at all hours of the night and day. then your credit cards are maxed out, your garage has more parts then you know what to do with and you have not seen the wife/girlfriend in a week.
the addiction to these old girls is a bitch once it gets hold.
- KZ1100 Bully
27 Jul 2009 09:45 - 27 Jul 2009 09:46 #309601
by KZ1100 Bully
It is to late for that I'm hooked. I think I like wrenching it more than riding it. Just love the sight of the little brown truck pulling up beside the curb with some new parts for my baby.
Last edit: 27 Jul 2009 09:46 by KZ1100 Bully.
