- Thank you received: 5
1 over pistons still available for kz650?
- anarki650
26 Jul 2009 13:01 #309411
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
1 over pistons still available for kz650? was created by anarki650
I found NOS sets of 1 over piston rings on ebay really cheap ($25 for the set). Just curious if anyone here knows whether 1 over pistons are available without costing an arm and a leg anywhere? Anyone? The Wiseco 700 kit is $700...would like to find something less expensive than that if possible to get my 650 motor strong again...
09 Kawasaki ER6n
Omaha NE
- bountyhunter
- Thank you received: 337
26 Jul 2009 14:15 - 26 Jul 2009 14:22 #309423
by bountyhunter
Replied by bountyhunter on topic 1 over pistons still available for kz650?
I remember reading Kawi stll sells new rings for the 650 for about $40/set ballpark, so they probably sell the pistons. Babbittsonline.com will show them and discount the price.
EDIT: I checked, the pistons are about $53 each.
Last edit: 26 Jul 2009 14:22 by bountyhunter.
- otakar
26 Jul 2009 17:34 #309457
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic 1 over pistons still available for kz650?
I thought you did not want to go threw the expense of boring out the cylinders? You should just go to the 700 kit than. You will have to buy the gaskets anyway. So spend the $590 total for the kit and do it right.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- KawiConvert
- Thank you received: 4
26 Jul 2009 18:42 #309479
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic 1 over pistons still available for kz650?
If your going to do that, spend a little more and 810 it.
- anarki650
26 Jul 2009 18:59 #309484
by anarki650
09 Kawasaki ER6n
Omaha NE
Replied by anarki650 on topic 1 over pistons still available for kz650?
otakar wrote:
My initial thought was to stuff a used motor in it and get it back on the road, if I was doing that I wanted to go with a bigger engine...
After pondering the situation a bit I came to the conclusion that a used motor is likely to be just as much work down the road, so I might as well do this one right...which means she's going to sit on the back burner for a bit until finances improve (I'm going into my first year of teaching and haven't had anything in the way of a regular paycheck in about 2 years now...)
Now I'm looking at options between going MaKaw and shelling out about $400, or spending a couple hundy more and getting the extra cc's and compression out of the Wiseco kit...
09 Kawasaki ER6n
Omaha NE
- DoubleDub
- Visitor
26 Jul 2009 19:08 #309491
by DoubleDub
Replied by DoubleDub on topic 1 over pistons still available for kz650?
Not like you really needed to eat this week anyways, right?
