- Thank you received: 4
Crank Journals?
- KawiConvert
26 Jul 2009 08:31 #309384
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Crank Journals? was created by KawiConvert
I am working on a GPZ750 engine and finally got the cases apart and had a question about the crank journals. I took as good a picture as I could get and here is what I have. My question is if these have a problem or if they are good enough to reuse. The spots on the one journal made me wonder and the way the hole around the crank oil passage looked like it had been ground a little (may have been before the crank was installed. Any ideas on if these are still good or do I need to start investing in journals and some crank work?
- KawiConvert
26 Jul 2009 08:31 #309385
by KawiConvert
Replied by KawiConvert on topic Crank Journals?
- PLUMMEN
- Thank you received: 104
26 Jul 2009 08:40 #309388
by PLUMMEN
Replied by PLUMMEN on topic Crank Journals?
yeah shes had some dirty oil in the past.the easiest test i know of to check to see if a crank needs help is to rub the edge of a penny across the journal,if it picks up copper off the penny it needs some help.do you have any better pictures?
- 550A2
- keep the shiny side up
26 Jul 2009 11:07 #309399
by 550A2
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Replied by 550A2 on topic Crank Journals?
You can also check and verify the crank journal oil clearance using plasticguage, its like a wax piece of string you put on the journals and torque everything down, without turning the crank. remove the journal caps and you should be able to see and measurre the thickness of the wax strip after it has been crushed. also see if it is tapered.
- KawiConvert
26 Jul 2009 12:32 #309405
by KawiConvert
I'll try for some better pictures today. The flash was reflecting and washing out the pictures. I was going to borrow a micrometer from a friend and check for roundness. I've got to do the same on the rods to make sure the piston pins haven't worn the rods. They had some dark areas from oil.
I'm worried that the cost of fixing it all may out do the benefits of the larger bore. That and if I send the crank in for work it is tempting to have lots of work done, and that leads to lots of other work and then an engine that costs more than the rest of my bike. Really I am hoping to put this one back together for the cost of wrist pins, gaskets, rings, cylinder honing, valve guides, seals, and a few other things. Otherwise it is going to be a 2 year engine build. However, I don't want to put it together once to have to tear it down in 6 months to do it right.
I don't have any history on the engine, other than when I picked it up it would not turn over, however, a little extra torque on the bolt on the right end of the crank and it popped free and turned over. My guess is a stuck ring as I didn't see any scratches on the crank. Compression was about 40-50 across all 4. Thats all the background I have on it.
- gane
26 Jul 2009 17:21 #309455
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Crank Journals?
Kawi,My eyes aren't what they were, but pic's look like plain bearings are just showing babbit material.would inspect big end rod bearings.if ok, would try this. Get some 600 or finer garnet stap, break (soak) in solvent, and polish crank journals lightly, replace bearing shells w/new (stock if options are avalible(on some bikes there are no opts)and plastiguage. if plastiguage is within + 10% loose, of spec. run it. worn main bearings lose oil presure, which as a result leads to greater wear at rod big end bearings. In a perfect world plain bearings see no contact and should never wear. unfortunalty mostly due to lack of oil cushion at at startup/low oil pressure /passing of debris, wear does occur. passing graft leaves linear striations on crank journal, low oil pressure polishes (eggs) journal at thrust angle. I don't see obvious signs of these. luck G
- APE Jay
- Banned
- Thank you received: 58
26 Jul 2009 22:16 #309524
by APE Jay
Replied by APE Jay on topic Crank Journals?
Send us the crank, we will check it out and if it is OK, we will micro polish it and send it back.
aperaceparts.com/mailers/crankmail.html
Jay
Jay
- KawiConvert
26 Jul 2009 23:49 #309532
by KawiConvert
I may drop it off next time I'm passing through to Lancaster. Downfall is saying no when you offer to lighten and balance it as well .
- KawiConvert
27 Jul 2009 11:13 #309625
by KawiConvert
- KawiConvert
27 Jul 2009 11:13 #309627
by KawiConvert
- KawiConvert
27 Jul 2009 11:14 #309628
by KawiConvert
- APE Jay
- Banned
27 Jul 2009 14:47 #309679
by APE Jay
Looks OK to me. Those grind marks next to the oil hole is something Kawasaki does.
Jay
Jay
