kz200 engine restore
- clutch85
25 Jul 2009 23:28 #309353
by clutch85
kz200 engine restore was created by clutch85
i have a kz200 engine that needs a new left side cover and was wondering if there were others models and sizes that would also work with this engine thank you!
- JR
- Thank you received: 448
26 Jul 2009 06:41 #309368
by JR
Replied by JR on topic kz200 engine restore
It all depends on year and model.
The way to find out is to go to kawasaki.com, owner info, parts diagrams etc etc. When you find the part click on the part #, in the pop up box click on the little yellow question mark and this will give a listing of where else used
For instance. I drilled down to a 1978 kz200A1 and got a list of 4 other models where the engine chain cover was also the same
kz200-A1A 1978
kz200-A2 1979
kz250-D1 1980
kz250-D2 1981
try it out and hope this helps
kz200-A1A 1978
kz200-A2 1979
kz250-D1 1980
kz250-D2 1981
- clutch85
26 Jul 2009 09:58 #309395
by clutch85
Replied by clutch85 on topic kz200 engine restore
awesome! thank you that helped a ton
