Isn't this supposed to be the dry side?
- deezil
25 Jul 2009 12:14 - 25 Jul 2009 12:16 #309265
by deezil
Isn't this supposed to be the dry side? was created by deezil
My Little Barn find KZ200 is still Fighting with me.
I noticed a little oil leaking from the Left Side engine case cover and decided to yank it and check it out.
I noticed the stator and flywheel were sitting in oil. I Just Assumed the stator was always supposed to be dry? I checked out Bike Bandit for a crank seal but the schematics do not show one?
This thing just cannot be half submerged in oil....Can it?
Am I missing something here?
Last edit: 25 Jul 2009 12:16 by deezil.
- MFolks
- Thank you received: 540
25 Jul 2009 13:08 #309272
by MFolks
Replied by MFolks on topic Isn't this supposed to be the dry side?
If your bike is built like the bigger 4's are, the alternator needs oil lubrication for cooling and the starter system over running clutch needs it too.
- deezil
25 Jul 2009 13:16 #309273
by deezil
Replied by deezil on topic Isn't this supposed to be the dry side?
I Guess it is . There isnt a Seal in the schematics and I for sure do not see one behind the setup.
Wouldnt the stator short out being wet?
- MFolks
25 Jul 2009 13:48 #309275
by MFolks
Not if the windings are coated/varnished when the alternator was built.Most are constructed with magnet wire that has a coating on it, and then after assembly the stator is put in a vacuum chamber where it is heated sealing the windings.
Go to www.electrosport.com and read up on alternator stator construction.
- gane
- Thank you received: 1
25 Jul 2009 17:44 #309294
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Isn't this supposed to be the dry side?
D, not familiar w/your bike, but if cover is still off, take a look at the cases. on engines which use oil bath for stator cooling there are open windows from stator area to crankshaft chamber. I believe there should still be a crank seal at either end in order to provide oil presure to big end rod bearings. luck g
- KawiConvert
- Thank you received: 4
25 Jul 2009 20:34 #309327
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic Isn't this supposed to be the dry side?
The stator would short out in dry conditions if it wasn't sealed. It'll work in oil or air and I've seen both setups used on bikes. Mainly the oiled are on streetbikes and air/dry are on dirtbikes.
- deezil
26 Jul 2009 16:49 #309445
by deezil
I guess this is where I was confused.
I have mainly ridden Dirt bikes or enduro's all my life so If thats the way it is.... I guess I Need to get me a New Case cover gasket and seal it back up and call it done.
Thanks for the help!
