CLUTCH PRESSURE PLATE BOLTS??
- szczupd
- !!!NEVER BACK DOWN!!!
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
1982 KZ750H LTD
- Thank you received: 2829
- Thank you received: 2235
1982 KZ750H LTD
- GPz550D1
Robert
1981 KZ550-D1
- Thank you received: 2098
...This all started because I would hold in the clutch and it wouldnt return...tried adjusting it as per the manual and that wasnt working....
Uncertain which manual is involved, but some of the manuals are incorrect or confusing regarding procedure for the clutch pushrod adjustment.
Earlier design = turn adjustment screw clockwise until lightly seated, then turn it 1/2 turn counter-clockwise, then secure its position with lock nut.
Later design = turn adjustment screw counter-clockwise until lightly seated, then turn it 1/2 turn clockwise, then secure its position with lock nut.
Good Luck!
- KawiConvert
- Thank you received: 4
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- Mark Wing
Mark
Yorba Linda Cal.
- szczupd
Don't know if it may be a problem but did you put the little ball bearing in with the shaft.
Mark
yeah I checked 10 times and right before I put the puisher in I checked again the steel ball is in thier I actually have gone down the line and deduced I have an extremely streched clutch cable if not move on to the next possibility
1982 KZ750H LTD
