deglazing clutch plates
- brianrae33
22 Jul 2009 06:43 #308629
by brianrae33
1982 kz1000ltd
deglazing clutch plates was created by brianrae33
was gonna deglaze my steel clutch paltes..wondering what would be best to use??scotch brite pads or fine grit sand paper..any thoughts??thanx..
1982 kz1000ltd
- Thank you received: 2829
22 Jul 2009 06:46 #308632
by 650ed
Replied by 650ed on topic deglazing clutch plates
If they have residue on them you may want to soak them overnight in oven cleaner. ed
- PLUMMEN
- Thank you received: 104
22 Jul 2009 08:21 #308649
by PLUMMEN
Replied by PLUMMEN on topic deglazing clutch plates
glass beading with low pressure works good,helps oil stick
- MFolks
- Thank you received: 540
22 Jul 2009 08:36 #308652
by MFolks
Replied by MFolks on topic deglazing clutch plates
A random orbit sander with some 120 grit sandpaper followed by cleaning with soap and water usually does a good job.
- brianrae33
22 Jul 2009 08:47 #308656
by brianrae33
1982 kz1000ltd
Replied by brianrae33 on topic deglazing clutch plates
also should i be sanding both sides??
1982 kz1000ltd
- Thank you received: 797
24 Jul 2009 08:07 #309034
by 531blackbanshee
Replied by 531blackbanshee on topic deglazing clutch plates
yes deglaze both sides.i have a spot on my sidewalk that has deglazed more clutch plates than i can recall,hehe.i know hillbilly.a figure eight pattern on the old sidewalk and some new frictions and back on the track.hth,
leon holmes
leon holmes
- loudhvx
- Thank you received: 1616
24 Jul 2009 09:38 #309043
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic deglazing clutch plates
531blackbanshee wrote:
Also, worlds largest sharpening stone. :laugh:
leon holmes
1981 KZ550 D1 gpz.
Other links.
24 Jul 2009 11:47 #309077
by 531blackbanshee
that's right,you should see the edge on my machette!
leon holmes
leon holmes
