kz900
- bhewitt
21 Jul 2009 14:38 #308459
by bhewitt
kz900 was created by bhewitt
We have a 1976 kz900 I was just wondering if anybody nows what the correct temperature would be using a heat gun where the exhaust hooks into the motor
- bhewitt
21 Jul 2009 16:58 #308475
by bhewitt
Replied by bhewitt on topic kz900
- 89LX
22 Jul 2009 09:25 #308659
by 89LX
1977 KZ650B1
Overbored to 66mm in '79 w/ Venolia pop-up pistons & RC400Pro Cams
Restoration in process.....
Replied by 89LX on topic kz900
Keep in mind that something as simple as the initial advance that you have dialed into the ignition will make a big different.
So unless someone is running the same combo with the same tune, it’s not going to be an “apples-to-apples†comparison.
My 2 cents....
My 2 cents....
1977 KZ650B1
