Time To Pull The Head, What Else Am I Missing?
  • MentalMike
  • MentalMike's Avatar Topic Author
  • God Bless America!
Re: Time To Pull The Head, What Else Am I Missing?
22 Aug 2009 17:35 - 22 Aug 2009 17:37
#315803
Well I finally got the head off and here's what I found when I pulled the exhaust off, serious oil seepage.
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
Last edit: 22 Aug 2009 17:37 by MentalMike.
  • MentalMike
22 Aug 2009 17:39
#315804
The following is what I found when I pulled the head.
1976 Kawasaki KZ900
  • MentalMike
22 Aug 2009 17:40 - 22 Aug 2009 17:42
#315805
Whoa...oops!
1976 Kawasaki KZ900
Last edit: 22 Aug 2009 17:42 by MentalMike.
  • MentalMike
22 Aug 2009 17:43
#315806
1976 Kawasaki KZ900
  • MentalMike
22 Aug 2009 17:44
#315807
1976 Kawasaki KZ900
  • MentalMike
22 Aug 2009 17:45
#315809
1976 Kawasaki KZ900
  • MentalMike
22 Aug 2009 17:56
#315813
You can see cylinder 1 is oiled up. What I thought was a gasket leak seeping to the outside of the engine seems to have been coming from the #1 exhaust port as shown in the first picture.
I'm assuming the exhaust valve is letting the oil buy, but any ideas on how it's getting in the combustion chamber in the first place? (Intake valves?) This would explain why I was seeing some smoke from the exhaust.
I'm assuming a valve job is in order. Any ideas?
Thanks
MentalMike
1976 Kawasaki KZ900
  • Old Man Rock
  • Old Man Rock's Avatar
22 Aug 2009 18:19
#315818
Carbon build ups, ah is what it is...
Exhaust port oiled... ouch....
But what really caught my eye is 1 & 3 exhaust port valves...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • bountyhunter
  • bountyhunter's Avatar
22 Aug 2009 23:52 - 22 Aug 2009 23:59
#315876
valve guide seals which fail regularly on KZ's. I just put in the third set (factory then replaced twice) of valve seals on my KZ750 at 75k miles right now. My seal sets fail at age (about 10 - 12 years, not mileage distance. If yours are original, they are certainly all bad. The rubber hardens from heating and cooling.
Your pistons look way better than mine did at the last tear down.
Last edit: 22 Aug 2009 23:59 by bountyhunter.
  • MentalMike
23 Aug 2009 09:25
#315942
Yea, I'm sure the seals are original. Although the engine has only 6k, I think I'm the first one to ever open her up.
With that being said, I've never done a valve job by myself. I have my old shop manual, but it's not exactly a picture tutorial. Is there a writeup that someone can share that will make the valve job go a little easier? I'm sure I can get the tools and parts I'll need at Z1.
Thanks fellas.
1976 Kawasaki KZ900
  • bountyhunter
23 Aug 2009 14:41
#315983
Thanks fellas.
Not sure I would try to do a valve job myself, the valve compressor tool is pricey and you only need it once in a while.
You will definitely need a factory manual to show how to set up the cam timing to avoid screwing that up. I got a CD-ROM factory manual for my 750 on ebay for $6.
23 Aug 2009 15:33 - 23 Aug 2009 15:34
#315996
If the bike has only 6,000 miles I wouldn't even be thinking about a valve job. I would just clean everything carefully (use solvents, nothing abrasive) and put on new valve guide seals. Ripping it apart, and especially if you're not experienced, is likely to create problems where none currently exist. 6k miles really is nothing on these engines. There are plenty of guys, including me, that have put more miles than that on them in one summer. Save the valve job until 60k. Ed
Last edit: 23 Aug 2009 15:34 by 650ed.
