Need Pitch On Cylinder Head Bolt - 650-750
- reborn650
19 Jul 2009 18:15 #308093
by reborn650
-1998 Jeep TJ Wrangler 4.0...
Need Pitch On Cylinder Head Bolt - 650-750 was created by reborn650
Hey gang- Haven't been around in a while since I had the bike parked last year and had another toy to play with for the summer.
Just got the bike running again and noticed a leak at the front of the engine where the head connect to the block. I recall putting the head back on a couple of years back and substituted an aftermarket bolt because the head on the factory bolt was looking a little rough. I am pretty sure I put a 40 mm on to get me through the summer and didn't have any major problems back then. Now it is leaking.
Kawasaki shows the bolt that sits underneath the front cam sprocket as 8X43 but it doesn't list the pitch. I am pretty sure it is 1.50 pitch. Can anyone confirm this pitch on the bolt?
The complicated part of this is that the head is a 1977 Kz 650 but the cylinders are from a 1980 Kz 750 that has been punched out for my 810 kit.
Thanks in advance for the help.
Cheers-Colin Firth -Ontario Canada
1977 Kz 650 Custom. 810 Wiseco, WG 29 Smoothbores, GPZ750 intake valves, ported and polished, Dyan Electronic Ignition, MAC Pipe, and lottsa other go fast goodies.
- kawsakiman
- Thank you received: 6
19 Jul 2009 21:03 - 19 Jul 2009 21:05 #308149
by kawsakiman
Replied by kawsakiman on topic Need Pitch On Cylinder Head Bolt - 650-750
hey collin. long time no hear.
they are 8 x 1.25. not sure of lenth but i know i have a couple kicking around here. you know the deal.
give me a day to measure them.
shoot me a pm with your address again. my address book got wiped in a big meltdown.
Last edit: 19 Jul 2009 21:05 by kawsakiman. Reason: to ask for e-mail address.
- reborn650
20 Jul 2009 05:59 #308184
by reborn650
Replied by reborn650 on topic Need Pitch On Cylinder Head Bolt - 650-750
Hi Steve - Good to hear from you. Now that I have the pitch, I should be able to pick up a match at a customer of mine that runs a hardware supply business. If I get stuck I'll give you a shout. Cheers-Colin
