Spectre 750 Cams (and maybe whole bike)
- Yojymbo!
19 Jul 2009 14:10 #308061
by Yojymbo!
Spectre 750 Cams (and maybe whole bike) was created by Yojymbo!
I found an 82 spectre 750 overgrown with ivy and no heads, the pistons are rusted to the cylinders (too bad it was bored over), the rest of the main bike is there (no seat or covers but it's a roller. I was reading that the Spectre is a fairly rare bike and had cams comperable to the GPZ. He offered em to me for a ten spot, I could not find specs on the cam just that it was comperable to the GPZ but somehow slower than the stock 750 which made no sense. They did look chunkier though and had very thick casting at the sprocket with a #4 stamped on it, looking much rougher than the stock 650s I pulled out.
Possible aftermarket? In anycase would the Spectre be a good hookup, I could get the complete roller for probably a hundred or 2. My real question is about the cams though.
- OKC_Kent
- Thank you received: 20
19 Jul 2009 15:04 #308066
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Spectre 750 Cams (and maybe whole bike)
You can go to Kawasaki.com and look up bikes that shared parts, like this.
I found that your 82 Spectre cams went on these bikes:
Exhaust
Model (16):
KZ700-A1 (1984)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-F1 (LTD Shaft) (1983)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
KZ750-H4 (LTD) (1983)
KZ750-L3 (1983)
KZ750-N1 (Spectre) (1982)
KZ750-N2 (Spectre) (1983)
KZ750-R1 (GPz) (1982)
ZR750-C1 (Zephyr 750) (1991)
ZR750-C2 (Zephyr 750) (1992)
ZR750-C3 (Zephyr 750) (1993)
Intake
Model (9):
KZ700-A1 (1984)
KZ750-L3 (1983)
Exhaust
Model (16):
KZ700-A1 (1984)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-L3 (1983)
Intake
Model (9):
KZ700-A1 (1984)
KZ750-L3 (1983)
Oklahoma City, OK
- Yojymbo!
19 Jul 2009 15:42 #308070
by Yojymbo!
Replied by Yojymbo! on topic Spectre 750 Cams (and maybe whole bike)
So they are equivilent to GPZ cams. I read that the heads were the same but lacked the extra porting GPZs got. In anycase I can pick up the head and cams for $40 or maybe less so I'm doing it. Now whether to take advantage of the well flowing 750 heads or pirate the valves for my 650 head...
- KawiConvert
- Thank you received: 4
23 Jul 2009 17:38 #308902
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic Spectre 750 Cams (and maybe whole bike)
The 82 gpz cams are not the same as 83-85. 83 and on came with more aggressive cams and from my understanding a better flowing head. However, with the 750 crank you should be able to run the newer cam chain if you can't already.
- Slowball
17 Aug 2009 12:17 #314601
by Slowball
Replied by Slowball on topic Spectre 750 Cams (and maybe whole bike)
great info. I'm having trouble finding where on Kawasaki.com you found this. Can you point me in the right direction? Thanks!
- gorack
17 Aug 2009 12:24 #314603
by gorack
Replied by gorack on topic Spectre 750 Cams (and maybe whole bike)
when you go to kawasaki.com. find the part your looking for click on it and when it comes up there will be a little? question mark click on it and it shows you what bikes share this partB)
