Valve clearance, who knows?
- Buachaillin
17 Jul 2009 11:30 #307592
by Buachaillin
Valve clearance, who knows? was created by Buachaillin
I am rebuilding my 82 Kz 750 spectre, and I am doing some work on the valves right now, and I was wondering if anyone out there knew, or had a book and could look it up for me, as to what the valve clearance is supposed to be.
this would be a huge help. I have a repair manual coming soonish, but I dont know i that will tell me or not, and the sooner I know the better. Thank you for your help.
- kaw74z1
- 0 to 60 in 15 minutes.
17 Jul 2009 11:39 #307594
by kaw74z1
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
Replied by kaw74z1 on topic Valve clearance, who knows?
2 or 4 cylinder?
- BSKZ650
- Thank you received: 14
17 Jul 2009 11:49 #307596
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Valve clearance, who knows?
I think the spectres are 4 cyl, there should be a manuel on the site that will tell you the clearance.
also,, maybe a mod will move this to the engine section,
- bountyhunter
- Thank you received: 337
17 Jul 2009 13:28 - 17 Jul 2009 13:31 #307607
by bountyhunter
Replied by bountyhunter on topic Valve clearance, who knows?
The twins manual spec is .05mm - 0.1mm which is .002" to .004", but I run mine at .003" - .005". The fours are likely in that same ballpark or just a shade wider. Some of them allow a max of 0.15mm (.006") on the exhaust side if my memory serves me.
Last edit: 17 Jul 2009 13:31 by bountyhunter.
