KZ1100 Big Bore Kit ?
  • Tedster
  • Tedster's Avatar Topic Author
15 Jul 2009 21:05
#307302
has anyone ever put a 1170 kit or a 1262 kit in a KZ1100 what size cams would you go to and where would you start with the jetting with a good header pipe,head work, porting work and so forth,i want to do this in the fall so the bike ain't laid up no more this summer,i was wondering what kind of power gain to expect,and should i get the crank welded
Ted
  • APE Jay
  • APE Jay's Avatar
Re: KZ1100 Big Bore Kit ?
15 Jul 2009 22:35
#307312
  • Tedster
16 Jul 2009 03:12
#307320
APE jay
thanks for the info i didn't see my motor on there list for the 81' KZ1100 i will have to do a little more research on it
Thanks Ted
  • larrycavan
  • larrycavan's Avatar
16 Jul 2009 05:01
#307325
Ted
Before you jump into anything, you need to decide how you want the power delivery. The cam is going to be key in that decision.
  • Tedster
16 Jul 2009 05:37
#307336
larrycavan wrote:
Ted
i was told from a guy here i met at a bike nite not to go over a 420 cam for the street,and actually i would probally put the 1170 kit in it,i don't need anything more than that to be honest with you i am not so sure it ain't cammed already the way it lopes,but i can't really figure that being a bagger bike
  • otakar
  • otakar's Avatar
16 Jul 2009 05:51
#307343
With the 1170 kit your sleeves will get very thin and you take the risk of the lowers dropping into your engine. Anything past that you mist re-sleeve and bore the cases. Anything past .400 lift cams you will have to start rebuilding your head even on the late "Bathtub" head which came out in 83 on the GPZ and continued on the "Specter" Once you go past 1140, be prepared to start poring in the money. The best choice is to go with a 1140 cylinder and a good port job and a Web-Cam #110 grind www.webcamshafts.com/pages/motorcycle/ka...ta/tc_1731_2567.html The pistons I chose are MTC 74mm J pistons. www.mtceng.com/index.php?page=shop.produ...virtuemart&Itemid=60 It will give you a good, treatable, reliable motor without the price tag going into the multi thousands. Have Larry do a good port job on your head and you will have a bike that will kick "A" and give you a lot of reliable years. You will also have to spend a few hundred bucks on a appropriate carburetor rebuild to work with this setup or a couple-few hundred on a set of smooth boars. I prefer the rebuilt BS34s, mine work fantastic at a fraction of the cost.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • APE Jay
  • APE Jay's Avatar
16 Jul 2009 09:41
#307379
Tedster wrote:
APE jay
Thanks Ted
THE FOLLOWING KITS ARE FOR USE WITH J-MODEL AND GPZ STYLE ENGINES
KAWASAKI J MODEL, EARLY GPZ ('81-82)
17MM WRIST PIN AND FULL HEMI STYLE HEAD
Ted, this is it. However, if you have a shaft drive, you might have the 18 mm pins
  • otakar
  • otakar's Avatar
19 Jul 2009 06:19 - 19 Jul 2009 06:32
#307993
Hi Ted
I just sent you a PM. I think this is the thread you mentioned in your PM to me. but I am not sure. I am presuming this is a KZ1100A1 Shafty. This bike is nothing more than a 1000CSR with a drive shaft and 100cc more displacement, to counteract the power robbing affects of the shaft.
email me at
otto@condormodels.com
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 Jul 2009 06:32 by otakar. Reason: add info
