Does anyone have a 4into 1 on a kz1100
- Tedster
15 Jul 2009 20:58 #307298
by Tedster
Does anyone have a 4into 1 on a kz1100 was created by Tedster
I finally got my bike out tonite just got it back together
has an exhaust leak under the left pipe not sure if its one of tha asbestos donuts or if theres a crack in the pipes,needs a little fine tuning after i get the exhaust leak fixed this thing seems to ride good and plenty of power
but i would still like to put a Vance and Hines 4into 1 header on it does anyone have a 4into 1 on there kz1100
i would like to know what one fits its,there is no header listed for this bike thats why i would like to know if anyone has one on theres so i know which one to order
Ted
Ted
- PLUMMEN
- Thank you received: 104
15 Jul 2009 21:02 #307299
by PLUMMEN
Replied by PLUMMEN on topic Does anyone have a 4into 1 on a kz1100
any header for 900/1000 should fit,you might need to make or modify rear mounting bracket is all
- Tedster
15 Jul 2009 21:09 #307303
by Tedster
Replied by Tedster on topic Does anyone have a 4into 1 on a kz1100
thats what i was told also,but if one would fit off from a certain model without any modifications i would like to put that one on it
Ted
Ted
- Thank you received: 2098
15 Jul 2009 22:13 #307308
by Patton
Replied by Patton on topic Does anyone have a 4into 1 on a kz1100
Often quite simple to fabricate a bracket.
Just cut and bend some flat stock to shape desired, bore a couple of holes, paint flat black, and attach.
I enjoy using a small rubber motor mount to attach the muffler to the bracket, which eliminates vibration otherwise imparted from the muffler to the frame.
Here's a pic on KZ900 LTD.
Good Luck!
[Click on image to enhance view]
Good Luck!
15 Jul 2009 22:24 #307309
by Patton
15 Jul 2009 22:29 #307310
by Patton
Similar bracket with small motor mount for Vance & Hines on Z1.
[Click on image to enlarge view]
Good Luck!
Good Luck!
15 Jul 2009 22:32 #307311
by Patton
- Tedster
16 Jul 2009 03:04 #307319
by Tedster
Patton
them are two very good looking bikes them things are sweet looking man good job,i used to work in a fabricating shop and have all the tools here for making anything i need made of steel,but if i could buy one that would bolt right up
that one would be my choice,looks like i will probally be making a bracket for mine though,hope someday my bike will be polished up as nice as yours
Ted
Ted
- otakar
16 Jul 2009 05:59 #307346
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Does anyone have a 4into 1 on a kz1100
MAC gives you all the mounts to fit your bike and they have a few affordable models to chose from. You can buy them directly or go to Bike Bandit.
www.macperformance.com/store/category.cf..._ID=626&CatLevel=top
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
16 Jul 2009 06:07 #307350
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
I myself prefer the MAC HTS canister muffler over the Megaphone muffler they have. The HTS canister has more power and is a bit quieter.
www.macperformance.com/store/category.cfm?SID=3&Category_ID=628
I also think that the sound is a bit crisper on the HTS over the megaphone. I find the Vance & Hines and Kerker pipes a bit too loud. In my time I have had every pipe under the sun, and the best pipe ever made is the first Yoshimura, which is no longer made but is VERY closely represented by the MAC. The reason for that is, that MAC made them for Yoshi back in the early and mid 70s.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
