white smoke when cold
- Davestradamus
thanks,
david
- Thank you received: 2098
With a cold engine, particularly on older bikes, the seals are at their hardest and with less sealing ability.
When the cold engine is first started, some oil in the top end seeps past the cold hard seals, down along the valve stem into the combustion chamber, which burns and smokes out through the exhaust. It usually doesn't harm anything, nor does it consume much oil. Just looks bad, and maybe kills a few mosquitoes.
The smoking is often temporary until the engine reaches normal operating temperature, where the heat softens the seals, which then resume better sealing, and eliminates the smoking exhaust.
Whenever the head is removed for some other reason, imo then is usually a good time to also consider renewing the valve stem seals.
Good Luck!
- Royal1MC
- Is it just me, or is it just great to be on a KZ
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
- KOOL RYDER
- KZ 650B2 / KZ 1000E
It was after I started the bike after I got caught in a downpour.
No worries. I keep the bike indoors and out of the rain.
I do not know if it was residual water that turned to steam and pulled some disolved crud out the exhaust.
Small potatoes.
KR
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- Old Man Rock
- Thank you received: 225
My KZ is doing the same and this is after a complete head valve, seal, guide, springs and P&P job....
I thought WTF, check my valve clearances, timing components, ignition, carbs you name it.... Then I came across this....
If replacing valve seals, stick with Kawi OEM Seals for after market seals have a tendency to do this...
Just a thought in case you just had work done in your head....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- bountyhunter
- Thank you received: 337
If they are available, Kawi hasn't sold the seals for the twins in a long time.
FYI: get Viton seals if you can, they last a lot longer than butyl rubber seals and seal a lot better.
...enviornment....
Edit Once upon a time knew how to spell .environment :laugh: :laugh:
- bountyhunter
Patton wrote:
...enviornment....
It's funny, I never realized I was a little dyslexic until I started posting and typing a lot. I flip letter pairs like that all the time, sometimes I flip two letter sets in one word. I usually notice when I proofread the post, not always.
Someday, they will invent something that let's us go back and change a post if it has mistakes in it..... what a day that will be.:laugh:
- wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- MDawnz1
- Thank you received: 27
I would think condensation,
If it happens more then twice after the bike has been warmed up.
Check your air filter/filters to make sure there is no water sucked into it/them.
1974 Z1a, still 903
- loudhvx
- Thank you received: 1616
Oil, as was previously stated, tends to have a bluish tint to it, and will have a distinctive odor. Burn some motor oil if you want to know what it smells like, or ride behind a two-stroke.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
