1045 vs 1075
- tw..
Re: 1045 vs 1075
16 Jul 2009 12:32
larrycavan wrote:
This statement really sums it up. I've always thought to myself when I rebuilt my engine it would be with 1075 pistons and some mild porting with cams. This seems to be an enjoyable setup. So I think I may go that route. Then on the next built I may go bigger on the cc's.
IMO, just get the street compression pistons and select carb size and camshafts that suit the way you really ride the motorcycle. Be honest with yourself. Be wise in your selection & you'll have an enjoyable motorcycle.
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
1978 Z1R
- larrycavan
Re: 1045 vs 1075
16 Jul 2009 19:37
Yep...I know you were not implying to over cam it to get around the static number...
- larrycavan
Re: 1045 vs 1075
16 Jul 2009 19:40
Hey.....who stold the edit button AND WHY DID THEY STEAL IT:huh:
- Old Man Rock
Re: 1045 vs 1075
17 Jul 2009 04:48
Edit function is back...
I was kinda wondering myself on why a 1045 when the 1075 is basically the same price for pistons & rings...
Nothing over 10.5:1 most definitely... Especially here in Arizona, that thing would sooooooo over heat.... :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- tw..
Re: 1045 vs 1075
17 Jul 2009 07:08
I know someone local that want to get rid of a 1045 kit pretty cheap. So I was wondering what differences I could expect. If buying used 1045 kit was really worth it when I really want a new or relatively new 1075 kit.
2-1976 KZ900 A4
1978 Z1R
1978 Z1R
- otakar
Re: 1045 vs 1075
17 Jul 2009 07:28
I doubt that you would ever be able to tell the difference in +/- 3% of displacement. The big difference will be in proper breathing. Think of it this way. My old Camaro with a 6.6L engine had around 290HP my jaguar with a 4.2L engine has 310HP. When the blower is engaged it has 400HP put your extra money in proper head work and a good set of street cams. I had the same dilemma on my J motor should I go with the 1140 kit or the 1170 kit. I decided on the 1140 due to a reliability factor and cooling. I doubt that the size difference would be 2-3HP for either of us. In my case the price was exactly the same. In your case you can actually save money. It's a no-brainer in your case.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: 1045 vs 1075
17 Jul 2009 07:32 - 17 Jul 2009 07:45
Look at Larry Cavanaugh's web sight. It will explain everything.
www.flowbenchtech.com/porting/CRH/kz-data.htm
According to Larry, the difference between a 1075 and a 1327 is about 3HP. What do you think it would be in our case?????
1.5??
1.5??
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 17 Jul 2009 07:45 by otakar.
- otakar
Re: 1045 vs 1075
17 Jul 2009 07:54
One thing about Larry C, is that he is not trying to sell you anything. He is just giving you raw #s to work with. I personally trust him implicitly. I have never met Larry in person, but I have talked to him on the phone a # of times and he is always willing to help and there is no BS from him. I would say, take the money you save and send him your head and gain 20+ Hp that way. you will still keep the reliability of the engine and have the honest HP you want.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
Re: 1045 vs 1075
17 Jul 2009 17:15
PLUMMEN wrote:
Amen! You said a mouth full. It's all about the intake closing point.
davel wrote:depends more on youre actual cylinder pressure than a number on the side of a box.with a set of long duration cams youre cylinder pressure will drop quite a bit13:1 is not streetable on an air cooled engine. Water cooling is a different story. Even a 10.5:1 KZ is a challenge to keep cool enough to run 93 octane without knocking. I've been able to manage well with a good oil cooler and fan setup on my 1075. But 10.5:1 is the limit with an air cooled head.
- kzz1p
Re: 1045 vs 1075
17 Jul 2009 17:17
otakar wrote:
And what would that extra 1.5 hp cost?
1.5??
- davel
Re: 1045 vs 1075
17 Jul 2009 18:12
kzz1p wrote:
Consider this: On a street engine, you want maximum cylinder filling (volumetric efficiency) in a usable power band. Say between 3000 and 7000 RPM. Expect 90% - 110% volumetric efficiency on a well tuned KZ in this RPM range. No way that is going to run on pump gas with 13:1 compression. Let me rephrase - 10.5:1 compression is the limit on a well tuned street engine with good volumetric efficiency.
As pointed out earlier, if your engine is in a horrible state of tune or your cam duration is so radical that you don't get decent VE until 8000rpm then maybe you can run 13:1 compression with 93 octane fuel on the street without knocking. The engine will run like s**t and have no power until you wind it up to 8K then it'll knock like crazy.
A 1045 or 1075 with 10.5:1 compression and mild performance cam is the foundation of a good street engine. Once you install the cam and piston kit, the power will come from tuning. In my experience, exhaust tuning is one of the most important and overlooked pieces of the puzzle. A good 4-1 exhaust with the right size baffle will go a long way to making broad streetable power. Also, a well tuned exhaust will "pull" air through the intake during valve overlap (scavenging) which aids in carb tuning.
PLUMMEN wrote:davel wrote:depends more on youre actual cylinder pressure than a number on the side of a box.with a set of long duration cams youre cylinder pressure will drop quite a bit13:1 is not streetable on an air cooled engine. Water cooling is a different story. Even a 10.5:1 KZ is a challenge to keep cool enough to run 93 octane without knocking. I've been able to manage well with a good oil cooler and fan setup on my 1075. But 10.5:1 is the limit with an air cooled head.
- kzz1p
Re: 1045 vs 1075
17 Jul 2009 18:38
Yes the dome on a 13:1 piston will hurt VE greatly. I would guess that most people could not tell the differance, between a 10:1, 9:1 or an 8:1 motor. So why stick your neck out and risk it all? I have seen more broken big block motors, then smaller motors.
Please remember the term "street sleepers" Some cam companies suggest very large lift and duration with stock air boxes, carbs and exhaust pipes..........
