Engine Troubles
- Genros
13 Jul 2009 07:11 #306682
by Genros
Engine Troubles was created by Genros
Hey all,
I picked up another KZ couple of weeks ago. Went to do a comp test and leak down test. Pulled the plugs
Plug in cyl 3, the bottom of it is smashed in. Is the motor toast? is there any hail mary savior trick? the motor was supposed to be a 1075 (but you never know til you tear it down) The bike did start and seemed to run ok?
- MFolks
- Thank you received: 540
13 Jul 2009 10:50 #306721
by MFolks
Replied by MFolks on topic Engine Troubles
The standard sparkplug for the older larger 4's is a NGK B8ES gapped to between .028 to .032 If a longer than stock plug was used, it's possible it hit the piston.
Have you done a compression check? This will let you know if there is engine problems along with a leak down check.
- Genros
13 Jul 2009 12:50 #306741
by Genros
Replied by Genros on topic Engine Troubles
just tested, everything checks out ok. Tuning crabs now to get er going
- Old Man Rock
- Thank you received: 225
13 Jul 2009 13:14 #306746
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Engine Troubles
Remove the plug...
Under ignition plate cover, rotate fwd (CW from right side of bike) the 17mm nut while viewing the piston rise for TDC... (flash light), piston dome show damage?
Rotate full 360 degrees of rotation a couple of times with the new spark plug inserted...
MANUALLY ROTATE SLOWLY!!!
If the plug is indeed hitting you'll feel it go bump...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
