Machining Older Lower Casing to Accept 750 JUGS
- Yojymbo!
12 Jul 2009 18:57
What has to be done to older style 650 lower engine casings and/or studs in order to fit 750 jugs?
- PLUMMEN
Re: Machining Older Lower Casing to Accept 750 JUGS
12 Jul 2009 19:04
im guessing youll just need to clearance the bores in upper case enough to clear the 750 sleeves
- Yojymbo!
12 Jul 2009 19:25
So the lower casing has to be reamed out to fit the larger 750 sleeves into it and that's all? Could that be done without splitting the cases and removing the connecting rods? If not hello 710cc.
- PLUMMEN
12 Jul 2009 19:30
its actually the top case half,if youre gonna build a motor id suggest splitting the cases and checking out the bottem end anyways to save troubles later
- Mark Wing
13 Jul 2009 00:12
You have to split the cases, the junk from opening up the cases would wipe out the bottom end for sure. You don't need to remove the rods unless your checking the clearances with plasti-gauge.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
