Fogging oil for the winter?
  • Alex_KZ1K
  • Alex_KZ1K's Avatar Topic Author
20 Oct 2005 16:32
#3060
I'm trying to decide if I should spray some fogging oil into the cylinders for the winter hibernation. I've heard that it's really hard to get the engine restarted the first time after using that stuff. We usually have some very mild days throughout the winter season when everyone rides their motorcycle, and if we have a few of these, I'm not sure I want to spend an hour trying to restart it, then refogging after my ride. Does it really make that much difference on an engine this old? It already blows a tiny puff of blue smoke from the left pipe every now and then...
Alternatives to the oil for winter storage? It will be stored indoors in a heated room BTW.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Fogging oil for the winter?
20 Oct 2005 16:54
#3065
Man your bike is lucky. Mine will be in a cold shed. I'm either going to fill the tank and add fuel stabilizer and run it then drain the carbs, OR I'm going to empty the tank and add a bit of clean oil to the tank and coat the inside as well as drain the carbs (that's what I did last Winter). Either way I should be able to fire her up if I get the urge. I will also be doing the other long storage items such as;
Bike up on centre stand and both wheels off the floor.
Some air out of the tires.
A bit of oil in each cylinder.
Battery out and inside, tricle charged once a month.
Oil and filter changed.
Bike cleaned and waxed.
Cover exhaust and air cleaner openings.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • RonKZ650
  • RonKZ650's Avatar
20 Oct 2005 19:40
#3119
If you're storing indoors in a heated room, you should have to no nothing. I would drain the carbs and tank if you don't want to smell gas all Winter. Still my opinion that if you do elect to leave the tank full, no need to add stabilizer unless it's going to sit >1yr. My bikes regularly sit as long as 3 yrs between starting, sitting in a shed covered in temps ranging from -20 to over 100. I drain the tank and carbs is all I do. Never had a problem with rust or any other aging problem, but this is Colorado, dry humidity most the time. I really doub't adding oil to the tank or cylinders helps anything.
  • galaxian
  • galaxian's Avatar
20 Oct 2005 20:14
#3136
When storing do not leave your tank empty. Fill it full and add fuel stabilizer. Rust forms very quickly whether you can see it or not. Its a chemical process. The same goes for the cyclinders.
Ron i have to completly disagree with you on your advice and you should concider yourself lucky if your bike has been starting the way you store it. I am not saying i am right and you are wrong just that i am disagreeing with you on how to store a bike.
There is tons of stuff out on the web...Google is your friend.;)
1977 KZ1000A1, 1979 KZ650 C3
  • Alex_KZ1K
20 Oct 2005 21:23
#3150
Hmm, I wasn't planning on keeping the tank full throughout the winter, but now I'm not sure. I don't have anywhere to keep the tank if it's full, I can't have it smelling up my basement. I'm probably still going to fog the cylinders, I'm just not going to put a stupid amount in there like my friends do. The carbs will be off the bike for most of the duration anyways. I'll be doing a soak, thourogh cleanout, and rebuild during the down time. :woohoo:
  • dannyg40
  • dannyg40's Avatar
21 Oct 2005 00:45
#3165
My lawn mower and summer equiptment I only run the carbs dry. Never used the fogging oil in them, and never had a problem. My old boat, and KLR650 I sold, I would use fogging oil. But I would also pull the plugs and shoot a little in there. Then I would hold it over the carbs and crank the motor for a few seconds. In the spring when I would go to start it, I would never have a problem starting the motors back up. If you put "way to much" oil in there, then you would have a small problem restarting. A half a teaspoon is plenty for each cylinder. I had put the KLR in the basement the first year so I can do the valves and other required maintanance, and the gas tank was empty, and in a warm basement. No rust ever formed inside.
  • JR
  • JR's Avatar
21 Oct 2005 05:19
#3184
My bike is stored outside in a garden shed. Like dannyg40 I put a teaspoon of engine oil in each cylinder. Remove the plug caps and turn the engine over a couple of times. This coats the cylinder walls with oil and prevents rust forming. Never used fogging oil and really had no propblems starting in the spring. In fact I always thought fogging oil was for spraying over the outside of the whole engine to keep it rust free if you were leaving outdoors.
  • Alex_KZ1K
21 Oct 2005 05:27
#3187
It's an aerosol can that comes with a straw, you have to spray it into one carb at a time with the engine running, then when you shut it down, you remove the plugs and spray some in through there.
  • JR
  • JR's Avatar
21 Oct 2005 11:55
#3257
Ah So.
Sounds like to much bother.
JR
Woodstock Ontario. Canada
1980 kz750 E1, 4 into 1, K&N pods
  • GargantuChet
  • GargantuChet's Avatar
21 Oct 2005 14:01
#3281
Hah! For those who haven't been to Colorado, there's no need to close bread bags or packages of crackers there either. It's so dry that crackers stay crispy for days... here in PA it seems you get a few hours at best.
(My girlfriend is from CO and I've been several times. Yes, it's a huge difference -- between the dryness and the altitude you need to drink *tons* more water there, especially when you first arrive. It's strange, but a place well worth visiting. Without humidity, winters seem so mild... 20 in CO feels like 40 in PA.)
If you don't live in CO, you'll need to oil it all. If you do live in CO, why oh why would you ever park the bike?!?
  • Alex_KZ1K
21 Oct 2005 15:57
#3301
That must be nice there then! I can't even imagine what that must be like. Here in Southern Ontario (surrounded by great lakes) we NEVER see below 80% humidity, even in the winter months. I'd love to check that out!
  • luvmykaw
  • luvmykaw's Avatar
21 Oct 2005 18:00
#3320
I've done the same thing as JR the last couple of winters and spring starting wasn't a problem. The bike will chuff n' fart a bit, then start and burn out the cylinder oil.
