Topend Rebuild in progress
10 Jul 2009 10:21 #305877 by RingB21
Topend Rebuild in progress was created by RingB21
Can anyone point me in the right direction to buying parts for my 82 kz440d1. I need a intake valve, head and base gasket, and piston rings. Ive been looking at bike bandit, etc... but they want an arm and a leg for parts and i just wasnt sure if there was anywhere else i could order them from at a much cheaper price..???Thanks
10 Jul 2009 10:49 #305883 by BSKZ650
Replied by BSKZ650 on topic Topend Rebuild in progress
look in the vendor section, but z1 would be my first stop, call them they can help
77 ltd1000, current rider
76 kz900, just waiting
10 Jul 2009 13:30 #305904 by bountyhunter
Replied by bountyhunter on topic Topend Rebuild in progress
You also need the O rings and valve seals to do the job. A vesrah top end gasket set is the lowest cost way to go. I got mine at Old Bike barn if I recall.
As for piston rings? I know where to get very cheap OEM piston and ring sets for the 750 twin and 400 twin, but not the 440. Z1 is always the first stop, but if they can't get them, try babittsonline.com as they have the lowest prices ordering OEM parts from kawi.... but, no guarantees that Kawi still sells the rings.
  • larrycavan
  • Visitor
12 Jul 2009 06:24 #306407 by larrycavan
Replied by larrycavan on topic Topend Rebuild in progress
Spring the extra money and put OEM Kawasaki valve seals in it.
12 Jul 2009 07:08 #306422 by Old Man Rock
Replied by Old Man Rock on topic Topend Rebuild in progress
What about valve springs?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
12 Jul 2009 14:29 #306523 by bountyhunter
I didn't know Kawi still made them. They certainly don't make them for the 750 twins, maybe the 440's?
12 Jul 2009 14:31 #306525 by bountyhunter
They usually don't need replacing, but the machine shop that does the head will test them.
12 Jul 2009 15:17 #306534 by APE Jay
Replied by APE Jay on topic Topend Rebuild in progress
If the 440 has 7 mm valve stems, then KZ1000 seals should work,
12 Jul 2009 16:14 #306541 by RingB21
Replied by RingB21 on topic Topend Rebuild in progress
Well it a little funny because we tore it all apart and I checked the rings by pouring oil over them inside the cylinders and leaving them over night and they didnt hardly leak a drop if any through them over an 8hr period. So we took the valves out and i figure we could look at the valve and see it bent so we cleaned them up and switched the 2 intake valves and there was no leaking by them like before.
So my question is what could it have been???? Maybe just too much carbon build up or what? Its very strange because before we pulled the valves out and cleaned up we retested them and nothing would leak through them at all....Very strange if u ask me.....Any input....
12 Jul 2009 17:37 #306555 by bountyhunter
Both times I had to do a head job on my twin, it was because oil seeping past the seals would accumulate and burn on in the seats and the valve faces. Eventually, there was enough crud built up to hold the valve slightly open.
12 Jul 2009 17:45 #306556 by bountyhunter
Good call, the cross reference shows the same PN:
92049-016
For the KZ 650, KZ 900, and KZ 1000.
17 Jul 2009 20:14 #307695 by RingB21
Ok guys so i got this thing up and running again but am having a couple problems. When u give it any gas what so ever it seems to stay up in the idle for a few seconds and then fall back off. I am not sure why it is doing this but it is really annoying. Can anyone give me any ideas. It runs alot better since the rebuild but i still need to do some tinkering and adjusting. If any one can help me out on this i would really appreciate it. Thanks
