Topend Rebuild in progress
- RingB21
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- bountyhunter
- Thank you received: 337
As for piston rings? I know where to get very cheap OEM piston and ring sets for the 750 twin and 400 twin, but not the 440. Z1 is always the first stop, but if they can't get them, try babittsonline.com as they have the lowest prices ordering OEM parts from kawi.... but, no guarantees that Kawi still sells the rings.
- larrycavan
- Visitor
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- bountyhunter
I didn't know Kawi still made them. They certainly don't make them for the 750 twins, maybe the 440's?Spring the extra money and put OEM Kawasaki valve seals in it.
- bountyhunter
They usually don't need replacing, but the machine shop that does the head will test them.What about valve springs?
- APE Jay
- Banned
- Thank you received: 58
If the 440 has 7 mm valve stems, then KZ1000 seals should work,
- RingB21
So my question is what could it have been???? Maybe just too much carbon build up or what? Its very strange because before we pulled the valves out and cleaned up we retested them and nothing would leak through them at all....Very strange if u ask me.....Any input....
- bountyhunter
Both times I had to do a head job on my twin, it was because oil seeping past the seals would accumulate and burn on in the seats and the valve faces. Eventually, there was enough crud built up to hold the valve slightly open.Well it a little funny because we tore it all apart and I checked the rings by pouring oil over them inside the cylinders and leaving them over night and they didnt hardly leak a drop if any through them over an 8hr period. So we took the valves out and i figure we could look at the valve and see it bent so we cleaned them up and switched the 2 intake valves and there was no leaking by them like before.
- bountyhunter
92049-016
For the KZ 650, KZ 900, and KZ 1000.
- RingB21
