79-80 Police / LTD cases?
- Jack
08 Jul 2009 08:45
Recently ,I was told that 79-80 LTD's and police bikes do not have the MKll cases with thicker stiffening ribs or the good crank. 2 motors in question - one has a eng.# in the 080000 range and the other is 111XXX.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Re: 79-80 Police / LTD cases?
08 Jul 2009 09:00
You might want to look at the thread called "why are there two kz1000 motors?" Further searches of the site will no doubt bring up a great deal more info on the subject.
- Mcdroid
- Gone Kwackers
08 Jul 2009 09:08
There is continuing confusion for several factors...
1) Common dogma says that the '79 B model did not have the MKII cases, while the '80 B model does have MKII cases/crank.
2) Common dogma says the '79 and '80 'A' model both have MKII cases/crank.
3) If you check www.zedder.com , you'll note that the C, A, and B models all drew motors from the same engine series (which includes the two numbers of yours in question). This is troubling as there were two styles of motors produced (older pre-MKII and MKII motors) and they are both listed as from the same motor series...which begs the question 'how can two different motors fall within the same motor VINs?'
Where the Police bikes fall in this mess, I don't know other than they were still produced with the older style (pre-J) motors through 1981.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
