riddle me this...
  • brianrae33
  • brianrae33's Avatar Topic Author
riddle me this...
07 Jul 2009 19:17
#305199
82 kz1000ltd..clutch cable is too long but don't think it's causing this problem..on occasion when i hammer it..it feels like the clutch cble goes completely slack..so i pull over..rattle the cable near wear it goes into the case..boom..pops right back..get back on hammer again..ditto..wtf??
1982 kz1000ltd
  • will61310
  • will61310's Avatar
Re: riddle me this...
07 Jul 2009 19:23
#305203
how is it during normal riding? any slack or play at all?
...1980 LTD 1000...
  • brianrae33
07 Jul 2009 19:29
#305205
no..fells very smooth..lubed the shit out of it..thinking it's the actuator that pushes on the cluthch rod to engage/disengage it...so maybe a new case..??
1982 kz1000ltd
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
07 Jul 2009 19:31
#305206
Have you actually followed the factory instructions on how to adjust the clutch? It's not enough to just set the slack at the lever.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • franknsr
  • franknsr's Avatar
07 Jul 2009 19:31
#305207
My vote is the combination of speed shifting and aged clutch springs.
Just a wild a** guess.
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
  • brianrae33
07 Jul 2009 19:35
#305209
hope you're right..and yes adjusted clutches at the case..
1982 kz1000ltd
  • brianrae33
07 Jul 2009 20:35
#305247
any thoughts as to what year has the shortest clutch cable??
1982 kz1000ltd
  • trianglelaguna
  • trianglelaguna's Avatar
07 Jul 2009 21:10
#305264
is the weak little spring inside on the cable where it pushes against the inner sprocket/actuators cases hole and the acuator arm?are all of the bolts on the sprockett cover tightened by a hand wrench to tight......is the clutch actuator set by the manual to a half turn back from seating and the lock nut tightened?is this the first step you took then worked your way back to the bars via the adjusters inline turnbuckles and then the final clutch perch adjuster......if so do you have a lubed and straight pushrod and bearing in the motor?and if so do you know if the springs or clutch friction plates are in decent shape????good luck ...craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • will61310
07 Jul 2009 22:38
#305276
i would try cable for an elr. they had superbike bars from the factory i believe, shorter than ltd bars and same engine
...1980 LTD 1000...
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
08 Jul 2009 02:01
#305287
You might explore 1978/1980 Z1R cables...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Buda
  • Buda's Avatar
08 Jul 2009 05:46 - 08 Jul 2009 05:48
#305302
You can get the standard J model cable, its what I got after I changed ther bars on my 82 LTD. Its 52.5 in compared to 58.5 in still a little long for my bike. www.z1enterprises.com/detail.aspx?ID=271
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Last edit: 08 Jul 2009 05:48 by Buda.
  • irishwill
  • irishwill's Avatar
08 Jul 2009 07:26
#305311
you might also want to check that your clutch basket is in good repair...if it is "notched" it will/could hang up the clutch....
something to check if the cable swap doesnt fix it
