Carb Question ???
03 Jul 2009 20:25 #304262 by ProStreet
Carb Question ??? was created by ProStreet
Its me again the saga continues I put the carbs back on the motor of a 77 kz1000 I am redoing, now I got gas pouring out of 3 carbs, Floats stuck ??? how do I fix it
Thanks
Tom
03 Jul 2009 20:33 #304265 by halkaloogie
Replied by halkaloogie on topic Carb Question ???
if you just rebuilt the carbs the seals could be in wrong, if not they might need to be cleaned it's easy just make sure you do one at a time and be sure to put everything back the same way
04 Jul 2009 00:53 #304292 by Patton
Replied by Patton on topic Carb Question ???
With some carbs it's possible to mistakenly install the floats upside down when reassembling. :pinch:
Also, sometimes helps to rap smartly and repeatedly against side of carb floatbowl with plastic mallet or large screwdriver handle while engine is running.
Where overflow persists, perhaps float tangs are maladjusted, or floats are damaged or defective.
Or further cleaning is needed of the float needle/seat interface where float needle interacts with the seat orifice.
Or new float valves are needed (both needle and seat). Some carbs have permanent non-removeable seats, whereby only the float needle is replaced. Where both are replaceable, it's imo best to replace both the needle and seat as a matched pair, married to each other forever.
Good Luck! :)
04 Jul 2009 07:00 - 04 Jul 2009 07:02 #304331 by bill_wilcox100
Replied by bill_wilcox100 on topic Carb Question ???
To state the obvious... be sure to have a good quality inline fuel filter after your petcock to keep stuff away from your Needle Valve seats. Don't ask. :blush:
See below:
Best of success. :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 04 Jul 2009 07:02 by bill_wilcox100.
04 Jul 2009 10:29 #304353 by ProStreet
Replied by ProStreet on topic Carb Question ???
Thanks guys I really appriciate it !!!!
Tom
