Loctite 242 ?
- Locozuna
05 Jul 2009 08:03 #304523
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Loctite 242 ? was created by Locozuna
After getting a late start on the aforementioned 900. My partner in crime and I have a question. We are installing the new oil pump and I think Loctite 242 is the one for the job. Since the docs do not specify which product to use I am asking the question to the brain trust here. Is this a job for 242? We will await the decree by downing another sudsy delicacy or two!
The pump screen was almost completely clogged. Now I got to figure out what to charge him for the new pump. I'm thinking a square trade for his Can-Am Spyder! :blink:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- fixer5000
- Thank you received: 5
05 Jul 2009 08:39 #304525
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic Loctite 242 ?
id think that sounds reasonable. looky here for specs on the 242
65.213.72.112/tds5/docs/242-EN.PDF
massachusetts
- Locozuna
05 Jul 2009 09:07 - 05 Jul 2009 09:15 #304530
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
Replied by Locozuna on topic Loctite 242 ?
Sounds good to me too. :woohoo: :woohoo: He's not buying it......I guess a case of Molson will have to do...but it better be Ice! :laugh:
I'm going with the Blue 242.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
Last edit: 05 Jul 2009 09:15 by Locozuna.
- MFolks
- Thank you received: 540
05 Jul 2009 09:54 #304550
by MFolks
Replied by MFolks on topic Loctite 242 ?
The BLUE Loctite # 242 can be removed with tools, but the RED Loctite # 222 needs about 300 F to loosen it's grip.
- bill_wilcox100
05 Jul 2009 10:19 - 05 Jul 2009 10:30 #304557
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Loctite 242 ?
Just a thought... Molson's Export is RED. :huh:
Labatt Blue is... well BLUE. :side:
I'd go with a two-four of Blue instead.
Oh, thread sealer... ya, the 242 Blue sounds like the way to go.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
Last edit: 05 Jul 2009 10:30 by bill_wilcox100.
- Locozuna
05 Jul 2009 11:00 #304568
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
Got a soft spot for Molson Ice(brain). Seems to only take half as much to do the job and that means only half the output too. I hope the Kidneys appreciate it because I do.
He got me to defy gravity and take a recon. Looks like the last owner hacked the stator plug and decided to goo it up real good instead of fixing it right. New problem. But I have a new one of them too.
Might be getting a lil Ginger Brandy to thin the beer. If this keeps up call me Spyderman.
But it sure looked like the stuff blocking the pump screen was gasket or silicone. The pan bottom had what seemed like hard tar in the bottom and the s-channel between front and back was just a hard dam of tar.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- DoubleDub
- Visitor
05 Jul 2009 11:03 #304569
by DoubleDub
Replied by DoubleDub on topic Loctite 242 ?
That's just scary.
- gane
- Thank you received: 1
05 Jul 2009 11:24 #304574
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Loctite 242 ?
Seat of pants, Locktite offers many grades of sealer/retainers most common in order of strength/temp are blue, red,green. Agree w/others, blue should be fine for oil pump application. G
- mtkawboy
- Thank you received: 16
05 Jul 2009 11:41 #304578
by mtkawboy
Replied by mtkawboy on topic Loctite 242 ?
and purple for small screws
