crankcase oil blow-by
- 1015bill
The pistons, rings and bore has 35k, bottom end has 60k miles. Oil level is correct. There is no exhaust smoke, or other problems. Runs fine, plugs are clean.
1975 900 Z1B, ZX6 REAR SWINGARM & FRONT END, 1015 KIT, ANDREWS CAMS,DYNA IGNITION, MIKUNI 36 RADIAL FLATSLIDES, K&N AIR FILTERS, KERKER EXHAUST & OIL COOLER, LED INTERGRATED TAILLIGHT & BLINKERS, GSR REARSETS, CORBIN GUNFIGHTER SEAT,ETC.
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
I my personal opinion! 35,000 miles on some top ends, are alot. And 60,000 miles on the bottom end, thats alot. If you are the second, third or tenth owner, who knows? Thats why they can't talk.
If you love the bike and plan on keeping it? Let it rest in peace and give it a complete rebuild.
- keith1
Bill, This is just an offering, and hopefully completly wrong.. but, if you have an escaped wristpin circlip/worn/gone teflon button, I've seen instance (1) where wrist pin has worn cyl. causing blow-by once piston was mid-way down stroke. This would explain good comp. clean plugs, yet blow-by. Exhaust all other alternatives 1st, hope I wrong G
if he had an escaped circlip, he d know it!!....if he used buttons, they are not known for longevity...could very well be the problem.......35k.. might just be time for a top end freshening up ..good luck ....
- 1015bill
- Old Man Rock
@ 3k you should measure 2.8 lbs, not 10 lbs...???
I recently just replaced my oil pump where I measured exactly 2.8 lbs at 3k rpm... In reviving up to 4K I then went to 10 lbs...
I would think at 3k if you're already at 10 lbs then you must be developing some serious case pressures at higher rpm's henceforth blow by...
Or am I missing something here...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
- Thank you received: 104
- bountyhunter
- Thank you received: 337
- 1015bill
Thanks for your input.
- Old Man Rock
One thing I can think of is a blocked cylinder passage up to the head/valves/camshafts... Meaning your oil is trapped down in the lower case, no flow...
Since you mentioned new oil leaks....
What about your oil filter itself, when was the last time you replaced... Just something to think about, no need to answer.... Possibly old gaskets and new pressures due to as Plummen menitoned, shiming the oil pump for increased flow....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 1015bill
