please help. exhaust problem
- happyhubby
03 Jul 2009 20:42 #304270
by happyhubby
1980 kz550 daily driver
please help. exhaust problem was created by happyhubby
i cut off my old mufflers because they had a couple rust holes and alot of scrapes. a buddy gave me hid harley take offs that fit perfectly. but it doesn't provide any back pressure. almost like a stright pipe but not as loud.
it boggs down very easily. starting from a stop into 1st it boggs down 9 out of 10 times like its flooding.
just adjust the idle air mixture to compensate or do i have to rebuild with new jets.
on a budget here so just want to make it run ok not pristine
thanks so much for reading and any suggestions.
- bountyhunter
- Thank you received: 337
03 Jul 2009 21:19 #304278
by bountyhunter
Replied by bountyhunter on topic please help. exhaust problem
My guess would be new jets are mandatory. Maybe adjust needles as well.
- happyhubby
03 Jul 2009 21:43 #304280
by happyhubby
Replied by happyhubby on topic please help. exhaust problem
is a kit for 4 carbs expensive? can i make my existing jets larger or should they go smaller
- Kawickrice
- Thank you received: 18
03 Jul 2009 22:41 #304287
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic please help. exhaust problem
Most likely you will need to go larger on your mains. How is the idle? Jets are relatively cheap but you should read up on jetting so you can order a couple of different sizes to experiment with.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
