- Thank you received: 7
Annoying exhaust leak
- Jack
02 Jul 2009 08:33 #303866
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Annoying exhaust leak was created by Jack
I have tried both headers on my MKll and can't rid it of the exhaust leak.Switched out old copper o rings for 4 brand new, tried 2 orings each port, tried 1 and 2 used orings in each port ,changed out washers & nuts , switched headers and leak persists no matter what I've tried so far ?
Cleaned the port mating surface and checked out the clamshells on each pipe. Running out of ideas and thought maybe someone else might have a thought on cause or possible solutions.Thanks.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- HerrDeacon
- Thank you received: 1
02 Jul 2009 10:08 #303874
by HerrDeacon
Replied by HerrDeacon on topic Annoying exhaust leak
A bit of high-temp RTV always works for me.
- Peterbilt
02 Jul 2009 10:11 - 02 Jul 2009 10:14 #303876
by Peterbilt
76 KZ 900 A4 Andrews 2x cams V@H exhaust 28mm Mikuni carbs off a KZ1000 rejected with accelerator pump removed and pod filters
Replied by Peterbilt on topic Annoying exhaust leak
Or try a Suzuki fiber gasket. Z1 part# k116-6063
Last edit: 02 Jul 2009 10:14 by Peterbilt.
- gane
02 Jul 2009 17:57 #303955
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Annoying exhaust leak
Jack, A common err in installation is to put the "clam shells" in backwards. The bent end faces retaining collar. Just a thought,Luck G
