Oil leaking from kickstarter
- DMR
28 Jun 2009 13:44 - 28 Jun 2009 13:59 #302758
by DMR
1980 KZ650
-Vance and Hines exhaust
Duluth, MN
Oil leaking from kickstarter was created by DMR
I recently changed my oil pan gasket on my '80 650 because of a leak but now I have a new problem. Oil is now leaking out from my kick starter. It's getting worse and worse so something has to be done about it. Before I crack into this, is there anything I should know to make this process of figuring this out easier?
1980 KZ650
Duluth, MN
Last edit: 28 Jun 2009 13:59 by DMR.
- KZ250LTD
- Thank you received: 16
28 Jun 2009 13:54 - 28 Jun 2009 13:58 #302767
by KZ250LTD
79 KZ1000ST
Past:
Many.
Replied by KZ250LTD on topic Oil leaking from kickstarter
Could just be the gasket and/or oil seal. Did this on my 750 just before I traded it, nothing tricky about it, just make sure you get all the old gasket off, press in the new oil seal, spray some spray gasket on the gasket itself and button it all up.
Edit:
Looking at the parts diagram I'm not sure its the same simple cover type system on your 650. If it isn't, disregard everything I said :laugh:
Edit:
79 KZ1000ST
Past:
Many.
Last edit: 28 Jun 2009 13:58 by KZ250LTD.
