spark color
- Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
Ok looking at my plugs i the core of the plug is black, and the firing tip is white...what does that mean?
I can only suggest, that you hold the plug wire while cranking the motor for 1 minute. This is the best spark test, known to man, at this time........................Good Luck! and keep us posted.
- Mark Wing
Mark
Yorba Linda Cal.
- kzz1p
:laugh: :laugh: :laugh: :laugh:
Mark
Well, it is a test? If it doesn't make you say bad words, then replace everything.
- Darkangel
- Mark Wing
Mark
Yorba Linda Cal.
- Mark Wing
Mark
Yorba Linda Cal.
- Darkangel
- Mark Wing
Mark
Yorba Linda Cal.
- Thank you received: 2098
Am thinking they are NGKB8ES, but should double-check the factory service manual to be certain.
As for the oil burning diagnosis, would ride it and not worry about it unless exhausting huge clouds of blue smoke.
Just keep an eye on the crankcase oil level.
And read the plugs again after 10~20 miles of highway cruising.
Perhaps the oil residue on the spark plugs results largely from old hard worn valve seals, which is a common non-dangerous condition on these bikes. It's usually worse at initial crank-up of a cold engine after the oil has had a chance to run down into the cylinders, and then burns off fairly quickly after starting the engine.
Actually, the latest most modern spark test is getting someone else to hold the plug caps. Such as perhaps an obnoxious neighbor kid. Or better yet, a bunch of them, holding hands. :laugh:
Good Luck!
- Old Man Rock
- Thank you received: 225
OMR
EDIT: Won;t allow attaching pdf files so here's the file in .DOC format (Word)...
Attachment Plug_Chart-007a90a6ce2004671c6bf32309f109a8.doc not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
