Custom cables
- Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- Thank you received: 2098
An able to suggest a shorter cable if needed for the modified handlebars.
Good Luck.
- Darkangel
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- kzr750r1
- Thank you received: 9
They were able to make a conversion set for me to mate the Mikuni RS to the Zephyr throttle assembly.
Once you have requested a cable they do not stock a part number is tagged to it for future orders if needed.
Good luck.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- Darkangel
WOW you guy were right. I called them and 40 bucks...that aint to bad... Here's a good question how do you measure accurately the length of cable you need. I thought about taking some string and routing it from the clutch to the up to the handle, and measuring the distance.
Imo it would be better to use an old cable rather than string.
The sheath length must be sufficient.
The additional exposed inner cable length should be remain a fixed constant regardless of sheath length.
It would likely be less expensive to purchase a shorter off-the-shelf cable from a similar model with lower bars (such as the shorter KZ1000-D2 cable onto a KZ1000-A, KZ900 or Z1 where shorter and/or lower handlebars have been fitted).
Z1E will likely have such alternate-use cable info readily avilable. And eliminate any risk of using the wrong dimensions for a custom cable. And receive it in one or two days.
I believe Z1E once offered Motion Pro custom cables, but no longer see a reference to that on Z1E's website.
Good Luck!
- Darkangel
Ok...I guess Im screwed I already modified the cable that I had.
New off-the-shelf at Z1E is about $16.
Cables aren't easily modified successfully, due the difficulty in properly attaching the end pieces.
The old fashioned "spread and solder" technique is no longer a first class fix, imo.
Good Luck!
- Darkangel
- bountyhunter
- Thank you received: 337
- Darkangel
