- Thank you received: 4
Oil Channel Bypass Lines for Head KZ650/750
- KawiConvert
Thanks,
KC
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- bountyhunter
- Thank you received: 337
- MFolks
- Thank you received: 540
1. www.redlinecycle.com
2. www.americanclassix.com
3. www.kzzone.com
4. www.aperaceparts.com
5. www.scnitzracing.com
6. www.reproductiondecals.com (not sure about this one)
7. www.sudco.com
8. www.dynoman.net
- KawiConvert
Thanks,
KC
- kzr750r1
- Thank you received: 9
In one of my half baked schemes I'd like to place a Gpz top end on a ZR bottom. Since the channel seal areas are different blocking and bypassing may work.
Haven't checked it all out and still just a thought.
What I have noticed interesting is the big bore plumbing for an oil cooler go behind the cylinder to the case. Not having a schematic for these makes it difficult to understand the flow.
Matching the existing orifice would be the paramount part engineering a 750 case to head bypass.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- MFolks
- Mark Wing
Mark
Yorba Linda Cal.
- Thank you received: 2098
I tried to search this one with no luck, but has anyone developed a kit for bypassing the oil channel that goes to the head and routing it through a line? I've seen it on some engines and was wondering what all was involved in doing it. Not that I don't like the oil channel, but it seems like lines would be more consistent, less likely to leak, and add a little more oil cooling to the engine than the channel does.
Thanks,
KC
Might find this thread of interest.
external oil line
Good Luck!
- kzr750r1
- KawiConvert
Thanks for finding that one Patton. A good read.
I'll second that. I thought I had seen something about it before but couldn't find the thread. I really wanted to see what it would take to get it done right.
- Cal
