- Thank you received: 1
engine question, please read.
- badboie
josh
- bountyhunter
- Thank you received: 337
The upper may need rebuilding, but the flooding is because the petcock is not shutting off and the float/seal assembly in the carb is leaking gas and can't cut off the gas flow securely.so I can't figure out why my engine keeps flooding out cylinder one. I have checked it out and I finally took it in to get it checked out... Turns out I need my upper end replaced or rebuilt.
- badboie
- keith1
- Thank you received: 2
yeah your right, and I bought brand new carbs for it. but still same problem, rebuilt the new carbs... same problem. The mechanic told me he thinks it needs to be rebuilt.... All I want it to ride my bike, its been over 2 years now!!!!!
sounds like the mechanic has a car payment due.....what do you mean by flooding out?....runs and then floods out? missing on start-up?....just wondering
- Thank you received: 2098
Install brand new spark plugs (per FSM specs) and visably observe spark quality on plug when removed from head.
And assure correct ignition timing, using a strobe type timing light. Confirm operation of advancer by watching it move back and forth as rpm's are varied by blipping the throttle.
Assure air filter is clean and flowing freely.
With decent compression and properly timed quality spark, may then proceed to assuring ample clean fuel supply through in-line filter to carbs.
Then use clear tube test to assure proper float bowl fuel levels.
Lastly -- after all the above -- address carb condition and tuning.
Good Luck!
- NUB118
IF YOU RUN......YOU'LL ONLY GO TO JAIL TIRED!!!
- bountyhunter
That should be easy to correct by fixing the carb that feeds it. make sure the float is OK, not leaky. Take out the needle valve and the brass seat and polish them: the tapered end of the needle and the area of the seat it sets in. Set the fuel level in the bowl to spec and it won't flood.so I can't figure out why my engine keeps flooding out cylinder one.
- eddiem
- KZR FLAG RELAY CARRIER #63
- Thank you received: 34
maybe junk in the tank
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
- badboie
One day I started up the bike and it ran like crap. so I got my dad to come out and listen. Thats when we decided to take off the spark plugs and check them out to see if they were ok or not. We tested them and they seem to be fine, they did spark. Then we noticed that the spark plug to the number one cylinder was quite wet but it DID however still sparked liked normal. so the next thing we checked was the carbs. we found that the carb associated with that cylinder was in fact stuck open and all the carbs were dirty so we stuck them in a carb bath and did a rebuilt on all of them. Droped them back on and it ran fine for about a day or 2 and same problem showed back up. so we just bought new carbs. Still same problem with even those. The bike does have an oil leak but from what the mechanic says its not causing this problem of mine but does need to be taken care of... duh. I really don't like this mechanic but he is the only guy around that will even work on older bikes. Everyone else hate working on older bikes and refuse to do so. So either the oil is leaking into that cylinder (which I believe it is) or I have spark or a carb problem still. Regardless to say, the mechanic says I should rebuild and that he would do it for around 700 bucks. I'm not spending that just to rebuild. so my bike has been sitting for a year and I'm really getting tired of having it there and not able to ride it.. oh and by the way... compression is green no problems at all there.
so I really appreciate all the help, thanks guys.
Josh
Good Luck!
- badboie
If not already done, would assure valve clearances to specs and then perform a leakdown test to help determine general overall condition of top end.
Good Luck!
to bad you don't live closer, at lease you sound like you know what your talking about. Wish the mechanic I go to sounded like he had half a brain. Thanks Patton I'll check that out.
- bill_wilcox100
- Thank you received: 5
IMHO, could be more than one cause for these symptoms. Do as suggested above... get a new good quality inline fuel filter installed ASAP. They are cheap. Try these gugs Link . This will eliminated any possibity of a dirty tank interfering with the the float bowl needle valve.
Another thought, swap the needle valve with one from another know working carb. If the problem follows the valve, you have found the offending part... disguard it.
Best of success.
PS
Please add your year, model and location in your signature to get the best responses and it's considered real friendly as well.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
