cam bearing bridge broke
- wes_scooter
24 Jun 2009 06:59 #301728
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
cam bearing bridge broke was created by wes_scooter
the bridge holding the cam bearings is cracked in two. can i weld it or use one from a diff head...
76' kz900
70' yamaha R5
2006 wr450f
- gane
- Thank you received: 1
24 Jun 2009 12:23 #301787
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic cam bearing bridge broke
Wes, I believe that heads and their caps were line bored at manufacture, Thus can't be purchased seperatly. That said, If you check, there are no options for sizing for cam bearings. IE "one size fits all". Personally I would try a "wrong" cap before attempting welding, and plasti guage (from the bottom unless valves are out) I've no experiance, nor knowlege of anyone trying this. If you do try, let us know if it works out. luck g
