head swap
- wes_scooter
24 Jun 2009 06:45 #301725
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
head swap was created by wes_scooter
will a head form a 82 kz1000 fit my 76 kz900
76' kz900
70' yamaha R5
2006 wr450f
- Buda
24 Jun 2009 06:57 #301727
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic head swap
With some modification it will, different cam chain parts and you will lose some compression. Others will have more info.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- StreetfighterKz
- Thank you received: 117
24 Jun 2009 08:28 #301757
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic head swap
Do search for "J-model head swap" or the like and you should find all the answers you need.
Later, Doug
Later, Doug
1989 Vmax
- larrycavan
- Visitor
24 Jun 2009 17:57 #301842
by larrycavan
Replied by larrycavan on topic head swap
Unless you plan on other mods to the motor for performance increase, it's not worth the cost & effort.
Those other mods would include:
New Pistons
Larger Carbs
Cams
For the money you'd dump into doing the J to KZ swap, you'd get better performance out of drop in cams on the KZ motor...
JMO
Larry C
New Pistons
Larger Carbs
Cams
JMO
Larry C
