- Thank you received: 7
cam chain tensioner
- toad
23 Jun 2009 06:01 #301512
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
cam chain tensioner was created by toad
can someone please explain how to adjust my cam chain with my tensioner., I believe I hear a little bit of ticking from it
thanks Toad
thanks Toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- toad
23 Jun 2009 06:03 #301513
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Replied by toad on topic cam chain tensioner
sorry I forgot it is a 75kz900
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- timebomb33
- Thank you received: 10
23 Jun 2009 07:56 #301524
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic cam chain tensioner
pull the ignition cover off and then using a 17mm wrench rotate the motor to the t mark on 1-4 then on your tensioner back off the lock nut and then back out the bolt then tighten down the bolt and tighten the lock nut put your cover back on the ignition and viola go for a ride it is that easy. every time i have explained how to do this there are all ways questions aboutwhy do you want the crank at the t mark on no 1-4 well its just so that you make sure that all the chain slack is at the back by the tensioner no other reason. one other thing never rotate the engine backwards always clockwise.
- DoubleDub
- Visitor
23 Jun 2009 08:11 #301526
by DoubleDub
Replied by DoubleDub on topic cam chain tensioner
When you say tighten, how tight is tighten?
- Thank you received: 2098
23 Jun 2009 10:33 #301540
by Patton
Replied by Patton on topic cam chain tensioner
DoubleDub wrote:
Snug, just snug. Keep Godzilla outta there! :lol:
Good Luck!
Good Luck!
- sabell
23 Jun 2009 18:00 #301619
by sabell
'78 KZ1000A2
'79 650SR
Replied by sabell on topic cam chain tensioner
After loosening the locknut how many turns should you back out the main bolt for it to work it's magic? I'm always afraid I will go to far and hear all kinds of stuff falling down in the motor.
Thanks,
SB
Thanks,
SB
'78 KZ1000A2
'79 650SR
- timebomb33
23 Jun 2009 18:23 #301628
by timebomb33
just back it off a bit if the cam chain is loose you will fell it spring forward a bit.maybe 2or three turns at most
- Old Man Rock
- Thank you received: 225
23 Jun 2009 18:37 #301636
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic cam chain tensioner
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
