Tranny Slipping
- cccampbe
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
back off the adjusters on the cable then go down to the main clutch adjuster in the counter shaft cover take the small coverplate off and then back the nut off back the adjuster screw out a bit then turn it in until it makes contact then back it out 1/4 of a turn hold it solid then tighten down the lock nut re adjust the cable but make sure you give yourself about an 1/8 " of freeplay at the lever it should be good then. if that doesn't do it pull your clutch apart and sand or rough up the steel plates with either a bead blaster if you can get accsess to one or use 3m pads to scuff the steels so that all the glazing is removed.
I agree with Tim.
I would add one more thing to the clutch adjustment. (Where the clutch cable goes into the case/side cover.) You will find the worm gear for the clutch push rod. Add a touch of grease to the worm gear, so it will move freely. And then lube your new cable, so it will last for years to come.
- timebomb33
- Bluemeanie
- Thank you received: 14
- brianrae33
1982 kz1000ltd
- cccampbe
- timebomb33
- brianrae33
- PLUMMEN
- Thank you received: 104
- bountyhunter
- Thank you received: 337
- timebomb33
