dropped rubbers into motors cases
- odl666
20 Jun 2009 17:37 #300952
by odl666
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
dropped rubbers into motors cases was created by odl666
I was tearing into my motor and accedently dropped two dampers form the pullies on the chain tensor. What do i need to do, Do i need to get them dampers out or is damage possible with them rattling in there. Thanks any help is appreciated
kz 650 b 1978
kz 650 b 1978
1979 gs750e
- jtmcculloch
20 Jun 2009 18:14 #300960
by jtmcculloch
76 KZ1075
93 ZR1100
71 Moto-guzzi 750
2001 ZR-7S
Replied by jtmcculloch on topic dropped rubbers into motors cases
Take a coat hanger and sharpen the end.
Then you can stab them and pull them out.
76 KZ1075
93 ZR1100
71 Moto-guzzi 750
2001 ZR-7S
- gane
- Thank you received: 1
20 Jun 2009 18:30 #300964
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic dropped rubbers into motors cases
Odie, If I recall correctly the top tensioner dampers had steel backs. And the 650 has a single row cam chain and starter drive. a poor situation, Get 'em out. start w/easiest , magnet on a stick & probing, then dropping trans pan and flushing w/ solvent. Even If I'm wrong and pads are'nt metal, the oil passages in the 650 uses "oil control orifices" bits of chewed up dampers could starve crank or cams. my 2 cents. G
- timebomb33
- Thank you received: 10
20 Jun 2009 19:00 #300969
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic dropped rubbers into motors cases
drop your oil pan that will be the easiest way it should only take about twenty minuetes
- odl666
20 Jun 2009 21:17 #300997
by odl666
1979 gs750e
Replied by odl666 on topic dropped rubbers into motors cases
Thank You gonna attack it tomorrow
1979 gs750e
- Silver Tiger
20 Jun 2009 21:21 #300999
by Silver Tiger
Bikes Owned
1972 Rickman 250 Montesa
1974 Z1 - Kz1000 Jug 1045cc 10.25:1,Port and polished,Oversized valves,Underbucket shims,36mm Mikuni RS Flatslides,Dyna 2000 and 2.2ohm coils, Webcams 435 @ 288° duration,Taylor wires,NGK iridium plugs
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
Replied by Silver Tiger on topic dropped rubbers into motors cases
i had that happen to my z1 and i didn't even know it the rubbers fell off because of not enough adhesive. after a ride or two i was fiddling around with the engine and decided to take the oil pan off and there they were in the pan. kinda a pain in the ass cleaning the gasket off pan if it a old gasket.but it didn't hurt the motor in my case to run it with the rubbers like that
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- odl666
21 Jun 2009 14:56 #301120
by odl666
1979 gs750e
got them out thank you!
1979 gs750e
- timebomb33
21 Jun 2009 15:08 #301125
by timebomb33
excellent, did you end up taking the pan off or did you find another way.
