- Thank you received: 16
KZ1000E (ST) cam chain
- KZ250LTD
18 Jun 2009 09:29 #300246
by KZ250LTD
79 KZ1000ST
Past:
Many.
KZ1000E (ST) cam chain was created by KZ250LTD
As I'm going to look at a KZ1000st with an engine rattle on saturday I was thinking of tensioning the cam chain to check if it is the rattle.
I'm just wondering if the tensioning process is the same as on a Z1 as I have the manual for the Z1 and know how to tension the chain on it. If it isn't the same, anyone want to give me a runthrough?
79 KZ1000ST
Past:
Many.
- Nebr_Rex
- Thank you received: 300
18 Jun 2009 09:38 #300250
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ1000E (ST) cam chain
just like I did on mine
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- timebomb33
- Thank you received: 10
18 Jun 2009 09:39 #300251
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic KZ1000E (ST) cam chain
should be almost the same in fact it will be.they changed in 81 to the other style.i just roll it over to tdc no.1 and set the tension.
- RonKZ650
- Thank you received: 240
18 Jun 2009 09:43 #300252
by RonKZ650
Replied by RonKZ650 on topic KZ1000E (ST) cam chain
The ST has an automatic tensioner. No adjusting to be done unless someone replaced the tensioner with the manual type like you have pictured. Look at the tensioner on the ST, it should just have a 6mm bolt tightened flush to the body where the manual one has the longer bolt with several threads visible and a locknut like in your picture. If it has the manual type for some reason, adjust it, but never turn the engine over with the bolt loosened like those instructions say. There's a specific point the engine should be rotated to, then loosen the bolt and retighten it. On a 1000 I'm not sure exactly what that point is.
- Nebr_Rex
18 Jun 2009 10:56 #300271
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Some times the original ones stick a little and need help.Just lossen it up, 2 turns and retighten.The first automatic tensioners had some problems.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- KZ250LTD
18 Jun 2009 11:08 #300275
by KZ250LTD
79 KZ1000ST
Past:
Many.
Replied by KZ250LTD on topic KZ1000E (ST) cam chain
Thanks! Hopefully that is the rattle. If not, probably wont end up with the bike
79 KZ1000ST
Past:
Many.
- Nebr_Rex
18 Jun 2009 15:22 #300349
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
it might also be the idler gear on top of the head
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- KZ250LTD
18 Jun 2009 17:00 #300398
by KZ250LTD
79 KZ1000ST
Past:
Many.
Well it has the rattle and it isn't running on #3 so if number three starts running with a new plug and if there's good compression across the board it may go either way even if it isn't the cam chain
79 KZ1000ST
Past:
Many.
